Help...At Track C6 Z06 Throttle response problem
Gang,
A guest at Autobahn has an issue with his C6 Z06. He's a newer driver so he asked me to take his car out to verify what was happening.
He reported throttle cut during a previous track session.
I took the car out 45 minutes later after checking all fluid levels and tire pressures. Before I even had a chance to get the car out of first gear within the blend line, it cut out on me.
It feels like T/C kicking in when you push the car too hard.
It happens in all 4 modes. After a few laps it seemed to go away and I tried everything to upset the car's balance.
The oil level is just below the middle hole on the dipstick so the in the snorkel doesn't seem likely.
It occurs with no rhyme or reason.
There are messages or dummy lights on the DIC which is even more confusing.
Thoughts?
Thanks,
Mike
Thoughts?
Thanks,
Mike
Thanks Wally,
Connections seem okay.
Thanks,
This is the first thing I thought of and also mentioned in my opening post. If you remember in the FAQ, I was the lucky one to have the first one come loose on my Z06 almost 3 years ago.
The gentleman is going to contact me with any updates.
My car did this once at pocono with AH on. I forgot to turn it off and the car was freaking out and "cutting out". I came in and turned AH off and the problem went away. That particular issue never came back and it only did it for a about 2 laps. I doubt it's mechanical or it would continue to rear it's ugly head. My car has been on the track 5 times since this occurence without issue. Ask him if any of his TC lights or anything come on while it happens, mine did.
It does not feel "mechanical", it feels electronic if that makes sense. I have found these cars have very complicated software compared to the C5 and I have all kinds of weird things happen, then never happen again. One fix is to take the car to the dealer and get the lastest software rev uploaded, this should clear up any electronic nannies, but will wipe a tune, so make sure the tuner has kept a copy and you can go back and get it reloaded.
C6's, especially C6Z are very touchy when it comes to the ECU. Also, test the battery to see how much life is left. My car had a poor battery for the last couple months and did CRAZY things. At an event at NJMP, I couldn't get the car into comp mode or T&H off mode, the windows would not go up, or go up 1/2 way. I put in a new battery and the car runs better, windows index properly, and no interference on the track from the ECU.
Even if the car is 12 months old, change the battery and see if that works, if not, have the dealer upload the latest software level. If that doesn't clear the problem up, it is something mechanical or specific to the AH.
First off, look for codes with a tech 2.
If the car has been tuned, some of the warnings could have been turned off. Not smart but possible.
It's possible that a cat is getting ready to go bad. This happened to me but I got a check engine light eventually. This will show up on a tech 2, the rear 02 sensors are sluggish. To me, this seemed more like an engine miss than a T/C issue.
It's possible that something is wrong with the sensor on the brake pedal. I had this problem too but it I got a service active handling message immediately. You may be able to replicate this by putting lateral pressure on the brake pedal.
On my C6 vert, intermittent loss of communication from the EBCM to the other modules can cause some weird behavior but not throw a code (DIC) until it happens more than X times. The codes can be seen by a tech 2 but not with HP tuner software.
Last but not least: I heard about a problem with moisture in a connector that can cause the car to throw lean codes, idle codes, etc. Again, this is more of a driveability issue than T/C but you never know. This may be a variation of that problem. The connector is supposed to be near the rear of the right front fender. There is supposed to be a TSB on this but haven't seen it yet.
The bottom line is: get a tech 2 on it to see all the codes then troubleshoot.
