ELF 650 Brake Fluid - Experience?
Old 09-27-2008, 01:29 PM
rikhek
rikhek's Avatar
Default ELF 650 Brake Fluid - Experience?
Anybody have experience with ELF 650 brake fluid.
At Hallett it's all they use in the race cars and in the race shop.
Price is really attractive, right in line with Super Blue.
FWIW, I'm well aware of Castrol and all the other fluid out there. I've read all the threads.
I'm interested comments on the ELF 650 fluid. Did a Forum Search and found nothing.
Rick
Old 09-27-2008, 02:55 PM
gkmccready
gkmccready's Avatar
ELF Frelub 650 brake fluid. DOT4 1L
High performance brake fluid, 100% synthetic.
Dry boiling point: 540F/280C
Wet boiling point: 343F/178C
SAE J 1704 FMVSS 116 (DOT 4) Can be mixed with all other synthetic brake fluids type DOT3/DOT4/DOT5.1 except DOT5 (silicone).
http://www.pegasusautoracing.com/gro...pID=BRAKEFLUID
SuperBlue has better wet numbers... I'll stick with my Motul 600.
Old 09-27-2008, 03:12 PM
c4cruiser
c4cruiser's Avatar
Wet numbers are the ones to use in comparing the same DOT grades. ATE Super Blue has a higher wet boiling point at 392 degrees.
And with ATE, you get two different colors in Super Blue (blue) and TYP200(yellowish-gold); they are the same fluid so it's easy to tell when one is flushed from the system and the other is in.
Old 09-27-2008, 10:46 PM
gkull
gkull's Avatar
Received 1,327 Likes on 1,057 Posts
Once you get 580 - 600 degree fluid and you have a problem with boiling. You need to address why it's getting that hot. bigger rotors and air ducking
Old 09-28-2008, 08:10 AM
AU N EGL
AU N EGL's Avatar
Choose a brake fluid with a WET boiling point as close to if not above 400* F and you will be fine. Change before each weekend
To ELF 650 Brake Fluid - Experience?
Quick Reply: ELF 650 Brake Fluid - Experience?
