Accusump Install?
Old 09-25-2008, 12:02 AM
Lt1er
Lt1er's Avatar
Default Accusump Install?
I just received the three quart Accusump with electric valve and sandwich billet oil filter adapter.
Myself and directions are not clear. This is a no oil cooler or remote filter. The adapter is not marked oil in and out. From what I understand I would need a plug in the output side and hook the tank to the block oil galley "in" side of the of the adapter.
None of the directions show the sandwich adapter. Who out there can help me make the next race?
Old 09-25-2008, 12:05 AM
trackboss
trackboss's Avatar
The inlet is the same one that goes to the center of the filter.
Old 09-25-2008, 12:22 AM
Lt1er
Lt1er's Avatar
So the oil comes from the pump to the outside of the oil filter media and then through the center hole on it's way to the crank blah blah blah?
So it's a typical screw job from the vendor. With four ends for the SS 10 AN line and no plug
That's what happens when you hire 8 buck an hour kids!
Old 09-25-2008, 01:56 AM
GettReal
GettReal's Avatar
I have mine running to the back of the block so I'm not help Had the block drilled for this while it was out getting fixed from when I spun a rod bearing
Old 09-25-2008, 02:39 AM
trackboss
trackboss's Avatar
What adapter do you have? Its typical on adapters to have and in and out simply because they are used for external oil coolers. If its one of those you simply plug the outlet. On some remote oil filter mounts there are two ins and two outs to allow for various plumbing configurations. Not really a screw job, but canton does sell sandwich adapters with only one port just for accusump installations.
Old 09-25-2008, 07:47 AM
Lt1er
Lt1er's Avatar
Well that would have been nice also. I mean to get the adapter with just one port. I'm just going to get a 10 AN plug today.
I was also thinking about what the other poster said about the block. I have tapped in pipe going to a oil pressure sender.
My original problem is that in extended turns I have to watch the pressure gauge even with a 8 quart RR pan. I have to let off when I loose oil pressure. Over the years different C-5's spin and others spin rod bearing from high "G" turns
Old 09-25-2008, 09:40 AM
abc 123
abc 123's Avatar
Skip the adapter, just go to the galley plug at the forward driver side of the block.
Old 09-25-2008, 10:06 AM
GettReal
GettReal's Avatar
If you already have it tapped I would go this route. I did spin a rod bearing on mine this year because my home track has a couple high G sweepers that kills cars left right and center. Having my 3 qrt accusump tapped into the block has done the trick, I still see 40+lbs going around those same corners that killed me before. I do have an on/off toggle switch installed in my armrest but lately I just leave it in the on position [reason for that] I have a 110lb blow off valve on the accusump and with a hot day, lots of driving, in the off position, pressure builds up and blew the 110 mark what a mess, so now I just run with it on.
Old 09-25-2008, 10:55 AM
Falcon
Falcon's Avatar
Where does the 110#'s come from? The engine oil pump doesn't pump that much, does it? Something has to build that pressure.
Old 09-25-2008, 03:26 PM
GettReal
GettReal's Avatar
When the accusump switch (manual toggle switch) is turned on, you're correct, it runs the same as the engine oil pressure which is typically between 40 and 60, but when the accusump is turned off I assume the pressure builds up from heat. Like how a gas can builds pressure from just sitting in the sun.
Now I just always run with it in the on position
Old 09-25-2008, 07:45 PM
Lt1er
Lt1er's Avatar
I was just under the car and installing the sandwich............. The accusump line would go right into the manual tranny clutch rod.
So I would need a pipe thread 45 or 90 degree output pipe
Does Canton sell a sandwich for a manual tranny by chance?
This is an older style small block
To Accusump Install?
Quick Reply: Accusump Install?
