What all do I need to install Accusump?
Don't want to take any chances with new $10k engine. It is a 402 al block, so I thought the 3 qt would be better than 2 qt. If I just want to use it on the track, the would a manual valve kit be what I need? Would electric kit tied to ignition be better due to pre-oiling? Any thoughts would be appreciated.
Just for sh*ts and giggles, would an Accusump have prevented the cracked ring in #7 in my old sc engine?
Use the electric and wire to ignition switch or put a separate toggle switch, but remember to keep it turned on, so that you have the pre oiling capabilities.
With a manual you have to mount with close accessibility to driving position. With the electric you can mount on drivers side frame rail inside fender well and run hose directly to front of block on drivers side.
There are some threads with good photos and directions if you do search. I would recommend the 25 psi electric switch model.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes
Total cost, around $1600....seriously. The parts are just the beginning. Wait until you price all of those itty bitty fittins....... But, that said, I am glad I have one. I now have a preoiler, an emergency supply for dry spells, and a really kewl off/on switch in my cockpit........
On my race cars I always use a manual valve. If it is a street car and the sump is not mounted inside the car you can still use a manual valve with a remote cable. On my C5 I have purchased an EPC electric valve. Do not use the standard electric valve as it does not discharge fast enough. If using electric it is best to use a switch and understand how to use it. Same with the manual. If you discharge the oil before firing the motor DO NOT LEAVE THE VALVE OPEN. A properly plumbed accusump will fill before the motor if the valve is left open. The correct way to do it if you prefer to pre-lube the motor is to discharge, close the valve, fire motor and wait for full oil pressure, then pulse the valve on/off for just a second or two each time until the accusump fills. Watch your oil pressure guage when opening the valve and you will see pressure drop. After a few pulses you will notice the oil pressure not drop as much and at that point just leave the valve open. The idea behind this is to prevent oil starvation. This applies to the manual valve. The EPC valve is new to me.
Thanks for the info. I am not that interested in pre-lubing as much as I am about starvation. I need to do some more research, but if I just had the manual switch and engaged it during track days, would that work? It doesn't matter whether I could reach it from cockpit. Maybe I am not understanding how it works, but that was my thought process, but I will research. Thanks.
Total parts cost $478 with electric hooked to ignition. Now if you are talking remote oil coolers and filters it goes up. I work at a race shop.
As to the other poster. Canton sells these pressure regulators in three values 25 being the lowest. Your better off just setting the air bladder to your application. When you first turn the ign. sw. you will see a spike in oil pressure as it preoils. then turn on the starter and fire the motor. The oil pump then starts to refill the Accusump
I have my air at 40 psi. I have a non bypass oiling system with about 80 psi at anything over 4000 rpm hot. In a turn my oil pressure never goes below 40.
I was told by the Accusump people that ~10#'s was all the air pressure needed when the Accusump was empty. Any more than that would make the engine oil pump have to work too hard as the sump filled and pressure builds. It'd be worth a call to them to verify that.
BTW, the valve on mine is electric with a toggle switch.
IMO, the Accusump would not have prevented it, since most ring / ring land problems such as yours happen not due to oiling, but due to added combustion stress on the stock parts. With your supercharged engine + stock pistons/rings + road course use, it was only a matter of time.
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Just my opinion. Been working for me on my turbo 355 setup.
Why so high of an air precharge? At forty pounds, the container will stop functioning and remain empty anytime the oil pressure is less than forty. Reducing the initial charge (to around 10#) will allow the cylinder to store a larger volume of oil (by allowing the internal piston to move further into the cylinder before the compressed air stops the piston).
I have over 40 psi at hot idle. So the cylinder is full all the time the motor is running. My gauge just driving around is usually over 60 and climbs right to 80 as the rpm goes up. I don't want less than 40 psi.
10 psi would scare me with a 4 inch stroker crank and 434 ci. I fire the motor hold it on 2500 rpm and 80 psi cold until the temp gauge gets up to 150 F water and then move the car.
I broke a nice forged crank shaft a couple years ago and nearly lost the block. A couple of year before that I broke a solid roller lifter and it was major damage. This is a race motor not some 100,000 mile daily driver. If I get 30 hours between rebuilds I consider it great
Now, lets jump to 80 pounds oil pressure. The piston will have moved to the center of the cylinder, as the charge air reached 80 pounds when it hits half its original volume. So, at this high precharge, the Accusump is only half full of oil. And when it discharges, it will stop doing anything for your motor when the oil pressure drops below 40 pounds. It's just front end weight ballast after that point.
If you precharge it to 10 pounds, the cylinder will fill to approximately 80-85% (at 80 psi oil pressure) before the piston stops moving, and it will also keep feeding oil back into your engine all the way down to 10 pounds. That's free insurance, both time and pressure wise.
I set all of mine at around 7psi pressure when empty. When full at idle a quick check with a guage shows roughly 7psi more than my engine oil pressure guage. ex. if the idle pressure is 30psi then the accusump will be 37. If there is much more than 10psi the accusump won't fill completely. I have taken these things apart and it takes very little pressure to extend the piston all the way for full discharge.
So true. I had the cooler installed at the same time. Of course, one does not have to figure this into the cost. Sorry for the confusion and thanks for clearing up the matter for those looking to do the mod.
the accumulator valve adds a pressurestat on the gallery side in front
of the valve.
All three version of the pstats are/were physically the same, they differ
only by the pressure value at which they have been calibrated to
actuate - the actuation adjustment screw resides under a cap plug in
the case of the pstat.
The purpose of the pressurestat is to electrically control actuation of
the accumulator valve, according to the pressure detected on the oil
gallery side of the valve. When wired properly, the pstat opens the
valve when gallery pressure falls below the set point and closes the
valve above the SP.
The accumulator valve features one-way operation when closed. This
allows oil into the accumulator when the valve is deactivated, enabling
the cylinder to fill fully. The closed valve holds this fill at the maximum
pressure attained in the galley during operation.
Without the pstat of the E.P.C., activating the valve would open it to
the gallery and the fill level of the accumulator would rise and fall
according to the pressure in the gallery. Full at full throttle, less full
at part throttle as oil pressure in the gallery drops. Thus during a
pressure drop 'event' at part throttle, there is less charge in the
accumulator for reserve use.
With the pstat, the accumulator fills through the closed valve and
remains full regardless of pressure variations in the gallery, until such
time as the pressure drops below the set point of the pressure stat.
Then the pressurestat opens the valve enabling the full accumulator
to discharge its contents as required. When/if the 'event' passes, as
soon as the gallery pressure rises above the set point, the valve
closes again - my vote is that this has some benefit in improving the
pressure and flow available for the engine components.
Incidently, while I have not seen the approach used by others, one
possible solution for preventing the accumulator from discharging at idle
is to add a switch at the throttle to only activate the accumulator
valve above a certain throttle opening position.
Further discussion and images appear in:.
Sorry, but that doesn't make any sense. If you lose an oil pump for some reason, your lowest operating pressure at that moment will be zero, and your setup takes a powder at anything below forty pounds.
Canton's recommendation - from pg 5:
ACCUSUMP™ INSTALLATION & OPERATION INSTRUCTIONS
SETTING THE PRE-CHARGE
Once the Accusump™ is mounted and the plumbing installed take some time to set the Accusump™'s precharge.
Improper pre-charge can result in many problems. To ensure your Accusump™ will work correctly follow
the steps listed here.
With the valve in the open position (electric units energized) and the engine not running; pressurize the
Accusump™ to 60 psi. This will ensure all the oil is out of the unit and the piston is all the way to the oil end. While
the Accusump™ is pressurized to 60 psi check all the fittings (gauges and lines) for leaks. Apply soapy water to each
area and check for bubbles. If possible, wait overnight to ensure there is no loss of pressure. For the unit to operate
correctly there cannot be any leaks in the air side. Temperature change will affect pressure.
Once you are sure there are no leaks, bleed down the air pre-charge to between 7 and 10 psi. Now when you
start the engine and open or energize the valve, the pressure in the air side of the Accusump™ should increase to
approximately that of your engine oil pressure. After you close the valve and shut your engine off, check your oil
level. Add oil as required to compensate for the oil being held in the Accusump™.
