Lateral Gs ??
Old 09-03-2008, 02:39 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Default Lateral Gs ??
I have a 2001 Z06. T1 bars, VBP springs and matched Bilsteins. 18"Hoosiers - 315 and 345 f/r.
What kind of Gs is this setup creating (max)?
1.2 - 1.5 G my guess??
Thanks in advance.
joel
Old 09-03-2008, 02:49 PM
RAFTRACER
RAFTRACER's Avatar
Maybe a little conservative, but in the ballpark...
Depends on venue, track surface , tire compound, ambient temperature etc,etc.....
Old 09-03-2008, 02:53 PM
robvuk
robvuk's Avatar
Peak readings will be a bit higher. Averages are another story.
Old 09-03-2008, 03:41 PM
thehammer69
thehammer69's Avatar
Thanks in advance.
joel
I've hit 1.5 G's on a common Super Stock Setup, So I could see higher for yours...
Old 09-03-2008, 05:34 PM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
I've had a peak of 2.5 G but 1.5- 1.75 is more normal
Old 09-03-2008, 07:56 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
A real 2.5 g's is impossible with these cars unless there is some impact. Many people quote their data acq systems, but unless you have the sensors correctly located at the exact CG AND mounted correctly, you can only use them for relative measurements.
Old 09-03-2008, 08:35 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Speed is a major factor -- 1.5 on an AutoX course is one thing. 1.5G through the climing esses at VIR or Watkins Glen is entirely another story !!
Old 09-04-2008, 07:35 AM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Thanks guys. I appreciate all the responses and input. I am more/was more interested in sustained lat Gs.
Old 09-04-2008, 08:30 AM
StealthLT4
StealthLT4's Avatar
My first auto-x was this past Sunday, and my head unit said 1.3g max lateral g's. I'm happy with that
To Lateral Gs ??
Quick Reply: Lateral Gs ??
