SCCA certification
Old 09-01-2008, 09:53 PM
Bristol
Bristol's Avatar
Default SCCA certification
Has any of you guys taken the SCCA licensing course at Spring Mountain.
If so how as it, and did you get your license?????
Old 09-17-2008, 07:41 PM
socalspringmountain
Premium Supporting Vendor
socalspringmountain's Avatar
Our SCCA licensing school is actually a recommendation school for your license. It is up to SCCA whether or not you get your license. Now everyone that has gone through our school has passed the program. We grade every student and give that to SCCA to look over and make a decision based on our observations and if that person can pass a physical. Our SCCA school is a lot of fun, you will learn a lot. You should try it if you are interested in getting your competition license.
Jordan
Old 09-18-2008, 12:12 AM
fatbillybob
fatbillybob's Avatar
SCCA gives schools and they are cheap if all you want is to be SCCA license eligible. You can get a NASA license these days and SCCA will recognise that too so then you can just jump either way. In fact NASA will accept SCCA too. Check it out I think I am correct on these points.
Old 09-18-2008, 10:23 AM
Bill Hetzel
Bill Hetzel's Avatar
Yep, correct. I've done the SCCA to NASA to run the 25 hours.
To SCCA certification
Quick Reply: SCCA certification
