c6 track exhaust
Old 08-27-2008, 12:33 AM
exracer28
exracer28's Avatar
Default c6 track exhaust
In the middle of creating a c6 into a track only car. I cannot use headers but I can remove the cats. Along with the cat delete I plan on running straight pipe over the rear. My question is does anyone make the exhaust pipes I need or am I getting into a DYI project.
Old 08-27-2008, 07:24 AM
AU N EGL
AU N EGL's Avatar
Check with LG
They may have an Off Road system
But no Cats may cause O2 sensor problems. Leave the Cats on but take the mufflers off
Old 08-27-2008, 09:41 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
Originally Posted by AU N EGL
Check with LG
You would want to re-tune the car after removing the cats, you should see about 5 to 7 hp extra without cats, then have the rear O2 sensor codes deleted. Rear O2's are just there for emissions anyway. I'm assuming you would want a re-tune anyway if it's going to be track only.
To c6 track exhaust
Quick Reply: c6 track exhaust
