New track products from DRM!!!
Former Vendor
New products that DRM is now marketing!!!
This is great news for the racer. DRM and Intercomp are now working together to make sure you are staying ahead of the pack. A long time ago, Doug started moving west of the twin cities. Across the street from our old shop, Intercomp were building scales and measuring equiment for trucks, plans, and other industrial applications. After a short talk with them, they started building and marketing for the racer. Now 20 years later Intercomp has equipment in just about every racing series around the world. Most of the products are built in Media, MN which is a short drive from our shop. They do import some parts from the UK also, but assembled in the great state of Minnesota. I will be getting the parts from them directly, or a major stocking wharehouse. So our supply chain will be fast and always ready to ship. I took a few minutes to gather a few products that we use here in our shop and at the race track. Which I figured you guys and gals could use to make your tires last longer and produce faster lap times!!! All Intercomp products can be purchased from DRM and I will have the more popular peices on our website. You can also visit for more information. http://www.intercomp-racing.com/ IF you are interested in a different product, please let me know!!!
Thanks!!!
Randy
www.dougrippie.com
763-477-9272
SW777 PROFESSIONAL SCALE SYSTEM
Part Number: 170127
# Displays to 1/100th of a percent!
# Stores 100 Setups
# Baseline Setup Recall
# Center of Gravity Calculation
# Selectable Display Modes
# Target Tune Feature
# Serial Output
BEST FEATURES IN CLASS
# 15" x 15" x 2.5"/381mm x 381mm x 64mm Billet Scale Pads
# 1,500lb/700kg Capacity per Pad
# 6,000lb/2,800kg System Capacity
# Certified to 0.1% Accuracy
# Giant 0.5" Characters with Backlit Display
# Full, 2-year, Warranty
# Standard 9-volt Battery Operation
# Also features Custom Display Modes: Oval Track, Road Racing, Drag/Rally, Nextel Cup/Busch, Dirt Track, & All Weights & Percentages.
SYSTEM INCLUDES:
* Billet Pads
* One Touch Indicator
* Race Car Management Software
* Pad Storage Case
* Serial Cable for PC
9-Volt Rechargeable Battery with Charging Cable
$1645
SW650R1 QUIK WEIGH SCALE
Part Number: 170126
Now displays to one hundredth of a percent!
SPECIAL FEATURES
# Stores 100 Setups
# Serial Output
# Full, 2-year Warranty
# Also features Custom Display Modes: Oval Track, Nextel Cup/Busch, Dirt Track, Road Racing, Drag/Rally.
SYSTEM INCLUDES:
* Billet Pads
* One Touch Indicator with Carrying Case
* 9-Volt Rechargeable Battery with Charging Cable
$1325.00
Part Number: 170125
# Also features Custom Displays: Total of all tires together and individually, Percentage, Dirt Track, & Total Weight.
SYSTEM INCLUDES:
* Billet Pads
$1025.00
======================================== ====================================DIGI TAL CASTER CAMBER GAUGE WITH MAGNETIC ADAPTER
Part Number: 100005
Industry's only fully Digital Caster/Camber Gauge!
Indicates to 1/10 of a degree and has a +/- 20 degree caster/camber reading. Up to 10 times greater accuracy than traditional competitor's bubble gauges. Standard 9-volt battery gives up to 100 hours of operation. Lightweight, aluminum design, with auto shutoff and inclinometer mode for pinion and strut angles.
Standard features include
# Compact Design Holds to Hub better
# Pushbutton On/Off
# Caster/Camber Select With Built-In Diagnostic Mode for Resetting CamberZero
# Backlit for night use
INCLUDES: Magnetic Adapter and Case
$346.99
Part Number: 102010
Industry's Highest Accuracy Bubble Gauge! CNC-machined, billet, aluminum housing with easy-to-read bubble display. Measures -6 to +6 degrees of camber and -8 to +8 degrees of caster with 0.25 degree accuracy.
INCLUDES: Magnetic Adapter & Case
$169.00
This is a must with the above two items. You can adjust and come back to the same setup every time. No more playing around with adapters, and etc. Fits all popular 14-18 inch wheels.
18" AUTO RIM CLAMP
Part Number: 100007
Commercial grade clamp fits most any size rim. Rugged design with two types of clamps guarentees a secure fit.
Use with our Digital Caster/Camber Gauge or Bubble Caster/Camber Gauge, with a magnetic adapter, to complement this front end tool.
Perfect for repair shops and vehicles with expensive aluminum wheels!
$239.00
Million uses and more, you can measure track temps, cooler temps, brake rotors, tires, radiators, header tubes (find dead holes). I used one in my kitchen.
INFRARED LASER TEMPERATURE GUN
Part Number: 360018-E
Displays current and maximum reads.
# -58° to 1022°F (-50° to 550°C)
# Accuracy: +/- 2% of reading
# 0.1° degree increments
# Celsius/Fahrenheit Conversion
# Backlit LCD Display
# Standard 9V Battery Includes pouch
$140.00
TIRE DUROMETER
Part Number: 360092
The surface of a tire becomes harder with every heat cycle and even new tires of the same compound can vary a great deal in hardness. If a tire is too soft for the track, it will overheat and may not last the entire race, but if it is too hard, it will not get up to the optimum temperature and traction will be sacrificed. Intercomp's Tire Durometer enables you to make the correct tire selections for any track.
# Type-A Removeable Tip
# Reads from 0-100
# Adjustable face
# Zero button
# ASTM Certified
$59.00
DELUXE PYROMETER
Part Number: 360012
Intercomp's proven digital tire/brake pyrometer. Voted the most accurate in the industry!
# Indicates 0-1500°F/-18 to 815°C
# To 2000° with the optional brake probe
# Coiled probe cord
# Display hold feature
# 1° or 0.1° indication
# Displays in °F/°C
# Ultra-quick display update.
Includes tire probe and case
$159.00
Part Number: 360064
Includes a high-quality, thumb operated bleeder and swivel nozzel on a 17" Goodyear Hose. High visibility with major and minor graduation marks.
# 2" Air Pressure Gauge
# 0-60 x 1 PSI
When you are making changes it is nice to know if you went the right way. This is a stand alone system that you don't need any other people to help with the stopwatch. This system can be upgraded with a printer, PC interface and etc.
$42.00
LAP TIMER SYSTEM
Part Number: 360050
The industry's easiest to use and most compact lap timer at just 4"x2.5"x0.8"/100x6x20mm.
# Single button operation
# 205-Lap Memory, which can be recalled later
# Indicates Lap Number Every Lap
# Backlit Display
# Serial Output
# Blanking Time to Eliminate False Triggers or Hits from Other Beacons
# Adjustable Sensitivity to Suit Unusual Distances Between Beacon and Display
# Easy Recall of Factory Settings
# Displays Lap Times to The Driver
# Easily Installed With Velcro or Tie-Wraps - NO HARDWIRING!
# Display Operates, For Up To 200 Hours, On a Standard 9 Volt Battery.
# The Beacon Operates Up to 40 Hours on Four AA Batteries.
# Interfaces With Intercomp's Race Car Management Software!
Includes: On-Board Receiver/Display Unit, In-Field Transmitter, and Carrying Case.
Printer, Race Car Management Software, and Interface Cable Sold Separately.
$325.00
Thanks!!!
Randy
www.dougrippie.com
763-477-9272
Part Number: 170127
# Stores 100 Setups
# Serial Output
SYSTEM INCLUDES:
* Billet Pads
* Pad Storage Case
$1645
Part Number: 170126
SPECIAL FEATURES
# Stores 100 Setups
# Serial Output
SYSTEM INCLUDES:
* Billet Pads
$1325.00
Part Number: 170125
SYSTEM INCLUDES:
* Billet Pads
$1025.00
Part Number: 100005
# Pushbutton On/Off
$346.99
Part Number: 102010
$169.00
18" AUTO RIM CLAMP
Part Number: 100007
$239.00
$140.00
TIRE DUROMETER
Part Number: 360092
# Reads from 0-100
# Adjustable face
# Zero button
# ASTM Certified
$59.00
DELUXE PYROMETER
Part Number: 360012
# Coiled probe cord
# Displays in °F/°C
$159.00
Part Number: 360064
# 0-60 x 1 PSI
$42.00
LAP TIMER SYSTEM
Part Number: 360050
# Backlit Display
# Serial Output
$325.00
Former Vendor
Wow,
I haven't had this little action on a thread that I started sence, I pointed out three broken leaf springs
Should I even spend the time on my website???
Randy
Randy
If DRM keeps expanding its line-up I'll never have to go to my current standbys. I'd love scales but it gets expensive fast to get a good setup with enough space to roll on and off the pads, etc. :-(
Its all good stuff Randy and looks like reasonable prices but some of it many already have and the rest may be a bit much for occasional amateur use. Now if somebody who lives close by wants to split the cost of scales then I may consider it.
Former Vendor
Hummm. Maybe a video on how to use scales without the drive up ramps and platforms. The C5 and C6 is pretty easy to do this. The C3 and C4 makes the ramps a must.
Randy
Randy
I'd love to see such a video, Randy. Heck, when I change (coil over) ride height right now I have to drive the car about 20ft back and forth a couple of times to get it to settle! You have no idea the "fun" I had chasing my ride height before I figured that out... I had been rolling 2-3ft....
