Pfadt Racing launches C5 Rear Tow Hook
1 Post
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
If you're looking for a lightweight, easy to install solution for your rear tow hook check out our new piece:
It's made of stainless steel and powdercoated red for durability - and to make it easy for the safety crew to find! It bolts in to existing holes on either the right or left side of the car.
This tow hook is also well sized for use on the front, but you'll need to drill two holes in the subframe. Retail is $75.
Let us know if you have any questions.
-Aaron
-Aaron
1 Post
St. Jude Donor '08
For the C6 we sell the Brey Krause unit. It is very nice and mounts to existing holes also. Check it out here.
Yep, no problem. It sandwiches between the stock hanger and the frame. The factory studs are plenty long.
Howie, sorry I can't find a picture from below. I will try to post that next week. To answer your question, it can easily be installed and removed for track days. It is just two 13mm nuts holding it to the factory studs. Honestly, despite how the picture on our race car looks, it really is tucked under pretty far. You would have to work to bang you shin on it. The way the C5 butt sticks out causes it to be pretty well out of the way.
Happy Thanksgiving!
-Aaron
Clears stock exhaust?
Do you have a pic of the install from below.
Is this something we could easily install and remove for track days ???
Happy Thanksgiving!
-Aaron
Thanks, Aaron. Order coming.
BTW, when you go to your site, then click the C5 link under Products you get page 1 of 2, but clicking "2" or "next" refreshes the screen, but you don't get to page 2. To see everything you ahve to click on either the suspension or safety links.
1 Post
St. Jude Donor '08
For the rear installation is a 1 on a difficulty scale of 1 to 10, on the front it will be more like a 4.
-Aaron
1 Post
St. Jude Donor '08
For the C6 (and C6Z) we sell the Brey Krause unit. It is very nice and mounts to existing holes also. Check it out here.
It is in the C6 section of our website, not the C6Z section.
-Aaron
-Aaron
John, It works very well on the front, but you need to drill and bolt it on. It is more of a project. I use it there. We are putting together some pictures and instructions for it's use on the front.
-Aaron
-Aaron
But I really should have a hook on track days
Waiting on pics.......
DH
LOL I just got mine on Wednesday, I didn't know it was a NEW product. I just saw it while ordering your coil overs
I'll be interested in the front as well soon, after getting my nose bent from getting towed off the track it seems like a GOOD idea now
I'll Keep an eye on your website, posting here helps as well...
C5 Rear Tow
Here is a under car shot of the Rear Tow hook installed on the Driver side.
The Tow hook is designed to use the stock muffler mount bolts.
The picture shows an aftermarket exhaust system that doesn't use the stock muffler mounts. It can be used in conjuntion with the stock muffler on either side, driver or passenger side.
Those nuts/bolts for that hanger aren't very big. You can tow a car without breaking those?
DH
You're correct. The exhaust will sit below the hook using the same mounting position. By installing this into the same position as your exhaust, you should not see any interferences.
Tow hooks are usually made of bright visible colors so you may be pulled from the sand as fast as possible. We do not have any in black due to this. I admit black would look nice on most cars. But i am not sure how useful it would be.
As far as strength goes. The tow hook has been used on our race car for over a full season and have had no issues to date. And we've had it in some pretty hairy gravel pits Keep in mind that this is a "tow hook" and is meant for pulling, not for lifting.
Installation
Here are a couple of photos showing the installation of our new C5 front tow hook. The placement can be on either side. The install will require the removal of a few under hood panels, drilling 2 holes and inserting 2 rivots into the frame. Installation is easy and looks great when finished! The tow hook will come with fluent instructions for all, and has great photos to guide you through. If you have any questions you can call any of us at Pfadt and we'll be more than happy to guide walk you through!!
The price on this new product is $90
and it comes with the Tow Hook, 2 Bolts, 2 Rivet-nuts and a simple to use riveting tool. The only difference between this kit and the rear is the extra hardware.
Drilling and Placement
The Finished Product
Race Car Tow Hook
Good Luck
Race Car Tow Hook
Good Luck
Race Car Tow Hook
Good Luck
Race Car Tow Hook
Good Luck
I guess time as killed the above links. Could you repost them or e-mail
the pictures to me, jayb(at)pobox.com.
I want to install the front Hook but am a bit nervous about pulling the front bumper off. Your web site says it is not necessary to remove the bumper, but you say on this forum several body panels have to be removed. Please explain the procedure.
Thanks,
Jay B
Pfadt tow hook
Brian,
Go to www.pfadtracing.com
click on docs then click on installation then on C5 front tow hooks.
The new website details installation and parts removal in depth.
I will get detailed installed pics to you after I get back from track tomorrow.
J.R.
J.R.
