Wilwood SL6's on the back of a C5???
Let's say I have a line on a good deal on some used SL6's (not sure if they're the wide's or not). They don't include any bracket or anything like that, but have SS lines intended for use on the front of a C5.
My questions are:
-TJ
PS- I just ordered my G-Stop front kit so I think they'd be matched up well.
My questions are:
- Are there any brackets out there that will let me use them on the back of my C5 with stock rear C5 rotors.
- Will the SS lines intended for the front work?
-TJ
My questions are:
-TJ
My questions are:
-TJ
You may be able to use Wilwood's bracket for their rear 4 piston kit, and shim it to fit the stock or larger C6 Z51 style rotor. Their site has good pdf instructions for their kits that show the part numbers for those pieces.
Or go the easy route and use a front rotor in the back, then use a wilwood or LG front bracket - you would lose the parking brake though, and as pointed out above, may need to resize the master cylinder.
My questions are:
-TJ
My questions are:
-TJ
