Help...Tire size question on a standard C6.
Hi Guys,
What are the widest tires you can run on a standard C6?
Will 275/35/18 fit the front? If so, what would you suggest to mate with the rears? Anyone run the same 4 sizes at all four corners ever?
Stock size is F 245/40/18 and R 285/35/19
Thanks?
Mike
Thanks?
Mike
Hi Dimitri!
The question is for a good friend of mine. I've tried all sizes on my Z06 and wasn't sure how that related to the standard C6 in terms of wheel wells and interior clearance.
Thanks!
Mike
Thanks!
Mike
For no rubbing issues and tires not sticking out:
Front: 273/35-18
Rear: 315/30-18 or 305/30-19.
For road racing, some folks are using 305 mm or 315 mm front and rear. However, those tires stick out and may cause damage to the fenders.
Front: 273/35-18
So we put the stoppers in to sreering rock and used different brake ducts.
Dimitri
Randy,
We've exchanged emails on this subject. However, you've not provided evidence that would indicate that a front 295/30-18 tire will not rub the fenders, stick out, or "hit anything during suspension travel."
GKMcCready, on this forum, tried 295/30-18 tires on CCW 18x11 rims and reported: (1) rubbing on the fenders, and (2) that these tires stick out beyond the fenders. This was on a C6 Z51. Note that these are 11" wheels. Will a 10" or 10.5" wheel make a difference here?
I would very much prefer to run 295 mm front tires on my C6 Z51, and I would purchase Fikse wheels to make that happen. However, I need to be absolutely sure that whatever I buy really works before I make the purchase.
This is not my car but Bill Neal's (of 10/10th's Motorsports) with 295/18/30ZR all the way around on the car. His car is lowered with -2.5 camber. He may be able to speak to any fender rub issues. HTH
Hi Guys I would like to thank Mike for this thread he did this for me. All I want to do is get a track tire other than the sc tires that are on there now. I know where I can get some good used 275/35/18 Hoosiers to play with. I do not want to change camber. I am hoping that the 275 will fit in the front. I will only track the car 4/5 times a year.
C6/Z51/MN6
Thank for all your in put
Henry
C6/Z51/MN6
Henry
