Track Day Check list, do you have one?
Old 11-15-2007, 09:36 PM
Kinkajou
Kinkajou's Avatar
Default Track Day Check list, do you have one?
I was wondering if you guys are using some kind of check list like the airplane pilots have, just to keep everything under control and not forgetting anything before, and during the track day.
I guess it would be nice to have one.
Old 11-15-2007, 09:57 PM
63Corvette
63Corvette's Avatar
Yes, and you should too. As you gain experience it will only grow longer.
Enjoy.
Old 11-15-2007, 10:14 PM
mikahb
Vetteless
Support Corvetteforum!
mikahb's Avatar
St. Jude Donor '09
I'm putting some lists together. When I had no trailer, it was pretty straight forward. Now, with a trailer, there is more junk I need to bring, and more junk I need to bring HOME with me too. I think it's definitely worth doing.
Old 11-16-2007, 06:01 AM
94ZR1#444
94ZR1#444's Avatar
Enjoy.
Old 11-16-2007, 06:11 AM
ReddyZ06
ReddyZ06's Avatar
Originally Posted by 94ZR1#444
Old 11-16-2007, 07:12 AM
97C5inSD
97C5inSD's Avatar
Yeah it's nice to have one. I strated off useing one that they show you at the HPDE and the track days and have only expanded it from there.
It's a good start if your looking for something to start off of. Like the others mine has expanded from that one
Old 11-16-2007, 10:06 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
I don't have anything on paper, but it's all in my head. I generall get the car up on stands and lay under it for 10-15 minutes just looking around and putting my hands on things. I check all the brake fittings/connections, check the rotors/hubs etc. Check all exhaust connections. Check the trans/dif for leaks etc.
Underhood I check all caps, check the wiring harness for rub at the rear of the driver's side head, check my serp belt, empty my catch can, etc etc.
It becomes second nature.
Old 11-16-2007, 10:42 AM
2000BSME
2000BSME's Avatar
it is VERY long. Almost take the kitchen sink when I go.
Old 11-16-2007, 10:46 AM
Cobra4B
Cobra4B's Avatar
^ Oh yeah... forgot about the checklist for **** I take... I write it out for that. I've found that if you take it you won't need it. I bring almost all my tools, spare everything, fluids etc etc etc.
Old 11-16-2007, 11:41 AM
Aardwolf
Aardwolf's Avatar
I just have a tub that is for track events, I keep spare tools/fluids in there and just have to take the tub with me. When I prep the car I also toss things in there that I think I may need. For example, when putting my track pads on I would remember to put those wrenches into the tub. The tub I have is just a large box but it's plastic and durable. The small spare jack won't fall through the bottom of it.
Old 11-16-2007, 01:02 PM
yakisoba
yakisoba's Avatar
Where a list will really help is when you have help. I've had folks offer to help me set up and clean up, and so forth, and it would have been nice to hand them a list and say "start at #5, and thanks!"
Old 11-16-2007, 01:25 PM
63Corvette
63Corvette's Avatar
Most important when you BUY a track car, be SURE that you get the setup and "checklist" included in the deal. And buy a sinning car;-)
Old 11-19-2007, 11:08 AM
waddisme
waddisme's Avatar
Old 11-19-2007, 11:54 AM
c4cruiser
c4cruiser's Avatar
My trailer has a storage box so that gets filled up at the start of the season and everything stays in it and I only have to replnish things that are consumable like oil, coolant, brake fluid, etc. I have a small list for stuff that goes in my truck like my tool box, jump start box, air compressor, and floor jack and jack stands. I keep my helmet in a bag along with a couple pairs of gloves so that's easy to grab and toss in.
Then I have a separate sheet for doing a car maintenance and safety inspection before I leave so I won't have any issues with the tech inspection at an event.
Old 11-26-2007, 10:29 AM
Z07coupe
Z07coupe's Avatar
Now that the '07 season is over or almost over, and most of us will have some time to kill, how about everyone helping to compile a list. We can then pick out the items which apply to each of us. Maybe break it down to catagories. Trailer equipment, extra car parts, all necessary safety equipment, fluids, drivers gear, etc.
This would sure help us newer track drivers.
Old 11-26-2007, 10:39 AM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
Sticky at the top is good for general track session & car prep.
http://forums.corvetteforum.com/showthread.php?t=673766
Here's a list, with some links, that you can use to start your list ...
http://www.z06vette.com/forums/showthread.php?t=105732
Old 11-26-2007, 10:50 AM
varkwso
varkwso's Avatar
Great start - I have an enclosed trailer - but do not have a complete duplicate set of tools/jacks (yet!) for the trailer so some are always in the "other' location when I need them.
There is the car prep checklist..
There is the track box checklist (for the non-trialer/open trailer crowd)..
There is the food/camping gear checklist (I have dedicated boxes in the trailer) for the paddock campers...
There is the trailer checklist (amazing how the brake fluid does not get replenished when you need it the most)
There is the checklist as you head to grid (helmet, straps, AH Off, intercom, etc.) - I have been known to leave AH on when I cycled the power for some reason...
Then I generally load all the tires/wheels that will fit in the truck bed...
To Track Day Check list, do you have one?
Old 11-26-2007, 10:20 PM
undertaker
undertaker's Avatar
Location: ECS : WTF did you break now and HTF did you break it this time
I keep my trailer in my driveway, its become its own storage unit, everything track oriented for teh most part stays in the trailer own tools, jackstands, ramps, etc. makes packing that much easier, all I need to do is neaten it up and secure it all down (on yeah and put the car in the back) Just found it easier to buy extra stuff for the trailer besides the normal tools in the shop because double duty with teh tools and crap would totally confuse me and I know I'd forget stuff.
Old 11-27-2007, 10:55 AM
Z07coupe
Z07coupe's Avatar
Thanks for all the info. You all have been very helpful. Be careful out there.
Old 11-27-2007, 12:12 PM
Quicksilver Z06
Quicksilver Z06's Avatar
Track day info from Chin:
http://www.chinmotorsports.com/faq/faq.asp
Quick Reply: Track Day Check list, do you have one?
