Tires, tires, tires
Tires, tires, tires
Currently I am running Toyo RA1's in 18 front and 18 rear config.
I want to have a second set for the track, noticed Hoosier now makes a R comp radial in a P295/30ZR19 which will fit the OEM rear wheel.
On the front 8.5" wide OEM wheel Hoosier has a P245/40ZR18.
Thought this might be a good soultion to saving 2700.00 for another set of Corsairs.
What do y'all think of this?
I run 255's on the fronts and 295's on the rears (Toyo R888s) on OEM size wheels, which are Z06 replicas. Got em for $750.
Then I have a set of OEM tires and wheels for regular street driving.
I'm running Hoosier 295x18 fronts and 325x19 rears. I bought a second set of comp. grey stock wheels and the setup works great. The Hoosiers are way stickier than the Toyos. I've lowered the car a lot both front and rear and there is no rubbing. For less than $2,700 you will be able to get a set of stock wheels and Hoosiers.
John
