Stainless Steel Brake Caliper Pistons
I do think the upgrade is worth it but I think most here would recommend NOT running dust boots, especially if you track the car. I don't and have not had any issues.
As you're obviously aware they will tend to melt and just make a mess and really aren't necessary with regular brake maintenance.
I used the SS o-ringed brakes for many years on my 79. The best pads are carbon metalic. Valvoline Synpower brake fluid is good to about 500 degrees. Or the wilwood 580. In a lapping car you can use the SS brakes with air ducting up to maybe the mid 450 hp range with race tires.
1 Post
Cruise-In II Veteran
I think that the SS pistons from DRM are the best bang for the buck thing you can do for the OE slide rail calipers. As Tom and John stated above, forget the dust boots, they will get cooked away in any case. Stainless steel has about 10% of the thermal conductivity of aluminum. BTW, titanium has about 40% the thermal conductivity of stainless steel.
Matl Thermal conductivity
Ti 6Al-4V 6.70 W/m-K
304 SS 16.2 W/m-K
Al 6061 167 W/m-K
(source: Matweb.com)
304 SS 16.2 W/m-K
Al 6061 167 W/m-K
I asked this question a few months ago
http://forums.corvetteforum.com/show...ss+brake+lines
But from the responses in this thread, it looks like they are a good idea.
I would be interested to hear the pros and cons (if there are any), because I was thinking about doing them as well.
Chris
Chris
I run the DRM stainless pistons with the PFYC titanium pad shields and I haven't had any melted boots on my track car. I do have air piped to the rotors though.
Former Vendor
The Stainless steel pistons are a great way of keeping the heat out of the seal area and fluid. The dust boots will melt at some point, the pistons will help just a little bit, but not much. But the inner seal will live a much happier life. So will the fluid inside the caliper.
Take a lighter to a pop can and see how fast it gets hot. We have been selling these Stainless pistons for over 10 years now and I don't think we have replaced any!!!
Randy
Randy
Former Vendor
The problem with the core exchange program is. Would you want a caliper that has been on a T-1 car for 6 years. Well no you would want the same condition or better then what you sent in. I have some calipers around here if you would like, I will rebuild them and send them out to you. Condition and useage unknown on the calipers around here.
One other option is, I can buy new calipers and install the pistons.
I WILL ALWAYS INSTALL SS PISTONS FOR FREE, as long as it's off the car.
Randy
Denny,
Randy
Randy
cj
I had a set of calipers with the DRM pistons and they worked great. When I bought new calipers, though, I didn't swap the pistons and the stock steel ones seemed to work just as well. DRM's brake ducts are a better investment, IMO.
Denny,
Randy
Randy
How hard is the swap? Anyone have any directions for it? I can't imagine it being that hard.
Former Vendor
Former Vendor
I will do a writeup with pictures on install. This is one thing on my to do list this fall-winter.
Randy
