Ok... so new car tracks hours not miles, when to change oil? Switch to synthetics?
CI 3-5-6-7-8 Veteran
Panoz track car gets the oil changed monthly w/ castrol regular 10w30. I'm wondering how I should go about changing the oil being that the car will be tracked 5-10x a year.
Also... I was considering a full trans/dif/motor swap to sythetics. In my Z06 I change the oil ever 3-4 HPDEs and the trans/diff annually.
Opinions?
Swapping to synthetics is ok right? If I remember it's an old wives tale that everything will start to leak etc. I think mobil 1's website addressees this but of course they're trying to sell oil.
Opinions?
Opinions?
Opinions?
I put Mobil1 into my diff.......diff side plate started leaking soon after.
DH
test it why guess? My testing tells me 2500 track miles before changing on my car with my temps. Also it will depend how much you add between changes.
I never believed that was possible. It doesn't make sense. Hogwash. nfw Then I had a 92 5.0. I put synthetic in it. The rear seal started to leak. I replaced the seal. The new one leaked. I had about given up trying to fix it when I remembered the 'ol tale. I put dino oil back in and in a couple of weeks, the leak stopped. I'm now a believer.
My GTRA currently has a small rear seal leak. I suspect that Panoz was running synthetic in it. By the looks of the oil there's no way they changed it monthly. I'm going to give it a couple of changes with dino oil and see how the leak is before I replace the seal.
The trans will need GM or Penzoil Syncromesh fluid. Penzoil makes Syncromesh for GM so buy the Pennzoil and save $6 a quart. You'll need 2.75 qts.
If I were me, I'd keep about the same schedule you had on the Vette. Change the oil after 6 months or 3 track events. Change the tranny and diff once a year.
Does the trans and diff have drain/fill plugs like the Corvettes? Or do you hae to remove the diff cover to drain, then fill in the top?
One obvious difference that you seem to have overlooked. You are now running FORD CRAP so you shouldn't expect it to perform like a Chevy!
Sorry man, I just had to say it
Anthony
Anthony
Trans has plugs similar to the Vette. The diff is even easier. There's a drain plug on the bottom. There's a hole in the side to check the fluid level and there's a plug in the top to fill. There's enough room to just dump the fluid into the top fill hole.
