Stoptech: Recommended Pads?
Old 10-31-2007, 05:29 PM
Silverton
Silverton's Avatar
Default Stoptech: Recommended Pads?
For those with Stoptechs, can you recommend pads for:
(1) Initial HPDE's with street tires (e.g., Hawk Black, Carbo XP8, Pagid Orange),
(2) Advanced HPDE's with street or R-compound tires (e.g., Hawk DTC-70, PFC 01).
Thanks!
Old 10-31-2007, 07:02 PM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
Which calipers do you have the ST-40 4 pot or the ST-60 6 pot?
So far my group of friends has tried
Pagid Yellow
Pagid Black
Hawk DTC-70
Hawk HT-10
PFC-03
PFC-01
Most days are at Road America
In my opinion the DTC-70 has the best bite, but they only last about 3 track days. They also seem to be very rotor friendly, one of the guys has over 9 days on a set of rotors using only DTC-70's.
The PFC-03 seems to be similar to the DTC-70 but not quite as much bite and they are more expensive.
The PFC-01 or the Pagid Yellow are a good comprimise pad between bite and longevity. The PFC 01's will last about 6 days and handle higher temps, but won't have the bite of the above pads.
Pretty much the same can be said for the Yellow, but I've heard of people driving through them, temp wise.
The Pagid black will last about 6 days but it won't have the bite and again I've heard of people driving through them.
The HT-10's are what we use in the rear with the DTC-70 front, I think that is the best combo out there, although I haven't tried the Pagid Gray yet. We will try a set out next year.
I haven't had heat problems at RA but there is a lot of room for cooling and all of these cars have spindle ducts and DRM extender ducts.
Hope this helps, I would rather have more brakes than not enough, so I wouldn't look for pads to match the tires I would put something on and drive the car, I guess it depends on the track but you have to have a **** load of braking torque to lock your brakes up at 100 mph, plus that's the ABS 's job.
Old 10-31-2007, 10:09 PM
MySR71
MySR71's Avatar
I have ST60's on the front and ST40's on the rear (thanks David Farmer for the great deal!). I run HPDE's with street tires. I called CarboTech to see what they recommended. They pointed me to XP10's for the front and XP8's for the rear's.
I've only done one HPDE day since getting the brakes but they did great. No fade issues at all. Very consistent braking. I haven't taken the pads out to check the wear yet. I don't have any experience with other pads so can't comment on how they compare to others.
Old 10-31-2007, 10:32 PM
63Corvette
63Corvette's Avatar
My 04 Z06 with Stoptechs runs Pagid Blue on the street, and Hawk HT14s and HT10s on the track.
My 63 Z06 runs PFC-01s on the track with stock 65, 66, 67 K-H disc brakes.
Old 10-31-2007, 10:34 PM
Silverton
Silverton's Avatar
How are these pads for dust and wear:
Street: Pagid RS 4-2-1 (Black)
Initial HPDE's: Pagid RS 4-4 (Orange), Pagid RS-14 (Black), Carbo XP8
Race: Hawk DTC-70 and HT-10, PFC-01, Carbo XP10
Old 11-01-2007, 12:03 PM
MySR71
MySR71's Avatar
The Carbo's didn't seem to be too bad in terms of dust but I have black wheels so I might not have been able to see it very well.
Old 11-01-2007, 01:41 PM
Z06Fix
Z06Fix's Avatar
Street tires I would go with the Carbotech XP10's front and XP8's rear. If you are running r-compounds then I would step up to the XP12/XP10 combo.
Old 11-01-2007, 04:53 PM
Geoff17
Support Corvetteforum!
Geoff17's Avatar
Thanks!
I have a C6 Z06, with Stop Tech ST-60 fronts and ST-40 rears. I use Hawk DTC-70 front and DTC-60 rears. I have 9 track days with about 40% left on my 2nd set. I had 10 days and about 40% on my first set. Same Stop Tech Rotor for all 19 days. The rotor is covered with heat checks, I can't hang a fingernail yet and the cracks are not going all the way to the edge but it looks close to needing replacement. I typically tun stock size Hoosiers.
Sure they are dusty but I bleed the brakes when I get home so I clean the wheels when I take them off-about 2 minutes a wheel. The pads are awesome, never fade, great bite and easy to modulate.
That said these are the only pads I have ever used so I can't comment on the others.
Geoff
Old 11-02-2007, 02:04 AM
Joy of 6
Joy of 6's Avatar
This is what I use on my street tired Z. (10's & 8's) I think the Carbo's are great for duration and consistency
Old 11-02-2007, 02:23 PM
Bman
Bman's Avatar
St. Jude Donor '05
HT14s and HT10s for the track.. but they are a bit pricy
Old 11-02-2007, 06:33 PM
Silverton
Silverton's Avatar
Any other suggestions for street pads (hopefully with low dust and easy to clean)?
Old 11-02-2007, 06:51 PM
MySR71
MySR71's Avatar
CarboTech makes street pads for them. I'm not sure who else besides the ones which come with the BBK's.
Old 11-02-2007, 07:23 PM
kentz06
kentz06's Avatar
Geoff
except I use the DTC-70 in the rears as well. Trying to see if that helps stabilize the car under hard braking.
Dean
Old 11-03-2007, 10:17 AM
Z06Fix
Z06Fix's Avatar
I am hearing so many bad things about the carbotechs these days that I may go back over to the hawks. I know the caliper design has alot to do with it, but do the wilwoods and hawks tapper as bad as the carbo's in the stock caliper?
Old 11-05-2007, 08:33 PM
Geoff17
Geoff17's Avatar
Dean
Dean, please let me know what you determine. Did you initially have DTC-60's in the rear?
Geoff
Old 11-06-2007, 08:43 AM
Allthrottleandsomebottle
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I use Hawk DTC-70 front and DTC-60 rears. Geoff
Have a new set for the 97' sitting on the work bench.
http://www.vansteel.com/ gave a great price on them......and a supporting vendor here on the Forum too!
Z06 pads have been fine till ya start threshold breaking, a tad bit of fade at VIR at the session ends but ok to deal with.
New set of front rotors for these pads and all will be good me thinks.....that's what Danny Popp said it needed
Steve
Old 11-06-2007, 09:12 AM
Falcon
Falcon's Avatar
I've not used Carbos, I use only WilWood H's so I can't compare them to anything else. The WilWoods do taper, but the fronts last me 3 race weekends (which is 6 races) and when I replace them they aren't used 50%.
To Stoptech: Recommended Pads?
Quick Reply: Stoptech: Recommended Pads?
