Preferences for track-worthy longblocks?
I'm at 90k on my stock internals LS1 and am thinking about a revvable displacement increase as part of an engine refresh.
Any suggestions? For now, this is still a daily driver that will be seeing track days. I was thinking something along the lines of a bored LS2, but for obvious reasons, want to stay away from running a max effort stroker.
Naturally, I'm looking to keep the costs down as well. No C5-R engines for me.
Thanks,
Dan
Thanks,
Dan
before H+C do a big radiator and possibly some tranny and diff coolers if you like to really run hard. LG has some big numbers from cam only on LS3.
When I did mine 5+- years ago I had the budget to look at also. Big motors then were 25-30. I decided to just go H&C, coolers, and then aero. I have been very pleased with the car and the performance is great. Vette Doctors said do you want a 30,000 motor to turn to junk with one bad shift? Car has still dynoed within 2-3 hp of original Vette Doctor dyno at 3 different locations with near 5,000+- so it has held up well after 6,000+ track miles it now has.
My world challenge engines were always restricted by rules, but the OEM crank is good. Dropping in some forged rods and pistons will give you a solid engine capable of running 7500rpm pretty reliably. However, if you don't mind keeping the revs at 6900rpm, the bottom end will likely be fine in an LS2/LS3 shortblock with a nice cam and heads. You should easily be able to hit 500+hp, which is plenty. Any more power, and you will just be toasting brakes unless you lighten the car up a lot.
Location: If you don't weigh in you don't wrestle Road America
The LS3 is a great package, but it's not a direct drop in, it has a 58 tooth reluctor wheel so you would either have to replace the reluctor wheel with a 24 tooth or run a newer ECM.
So if you have to crack the engine open anyway, you may as well look at an upgraded crank with the correct reluctor wheel. The LS3/L92 blocks are going to be less expensive than the LS2 blocks, because they are used in the truck lines, many of the aftermarket guys are still working on there LS3/L92 packages so it will be a little while before you see them out there.
If you are mainly going to be tracking the car working with someone like DRM or LG may be a good idea, it may cost a little more then some of the other builders, but they know how to make a motor last in our kinds of conditions.
Also keep an eye on Scoggin Dickey, typically if GM comes out with it they will have it first.
http://www.sdparts.com/categories/LS...rformance.aspx
Thanks for all the responses!
Yes, I have no problems keeping revs under 6900 and an upgraded radiator will be going in the car before next summer anyway. I hadn't thought of the tranny cooler, but will add that in when the tranny and rear get redone.
Yea, I'm at the point now with the mods on the car that I'm looking hard at a set of heads. With the long term picture in mind, I'm thinking just hold off and get ones to match the bore increase.
The 402 packages look interesting. I like the idea of a square 4.0" x 4.0" setup. If it wasn't for that whole slowing down and turning business, I'd love to go with one of the gonzo iron block lsx buildups some of the ls1tech guys are doing. I'm such a ho for torque....
Thanks again,
Dan
Thanks again,
Dan
Thanks again,
Dan
Thanks again,
Dan
once you crack the motor you will be going for more coin. So LS3 will cost you a bunch. May as well go 402 on an LS6 block that seems to be the biggest to be dependable. Nothing is cheap by a good builder. BUDGET is the word how much do you want to spend. Motors. cooling, brakes, brake ducts, headers, air intake and so on. Are you doing the work or someone else going to do it all?
Or Katech's new 500 ci
Katech Performance 8.2L C6RS Engine Specifications
Engine: Katech Performance 8.2L C6RS
Type/Layout: 90 degree V8
Valvetrain Configuration: Pushrod over head valves, 2 per cylinder
Displacement: 8.2 Liter (500 cubic inch)
Bore x Stroke: 106.8 x 114.3 mm (4.205 x 4.500 inch)
Compression Ratio: 11.0:1
Horsepower: 600 bhp @ 5800 rpm
Bhp/Liter: 73.2
Torque: 600 lbs.-ft. @ 4600 rpm
Redline: 6200 rpm
Fuel Injection: Sequential port injection
Recommended Fuel: Premium unleaded
Component Features:
Block: 6061-T61 billet aluminum
Cylinder bores: Liner-less Nicom coated parent aluminum
Main bearing caps: Billet steel
Cylinder head: LS7 production sand cast aluminum
Crankshaft: Forged 4340 steel
Connecting rods: Forged steel, special alloy
Pistons: Forged 4032 aluminum
Bhp/Liter: 73.2
Redline: 6200 rpm
Component Features:
Bhp/Liter: 73.2
Redline: 6200 rpm
Component Features:
Bhp/Liter: 73.2
Redline: 6200 rpm
Component Features:
how much is that Tom?
600 lb ft good bye Hoosiers
Jason did not say.
They will announce the price and post dyno graphs, plus non emission legal cam options at SEMA.
Special made Warhwrk block IRC for Katech.
Not only good by to hoosiers, but transmission, diff and out put shafts and . . . . . .
If you are making a "track dawg" build the engine you want to. If you are planning on any "competition" you will need to see what the rules do to you for motor mods.
When I detonated my 130000 mile LS1 I bought a LS6 block and bottom end (used)...
