Koni 3013 1023/24 - anyone using?
These are the "upside down" shocks where the shock body attaches to the car & just the rod goes to the LCA.
I have been using for about 6 months & had to return 2 shocks because the front (lower) rubber bushing works it's way out of the metal circle.
Anyone one else using these/any problems?
Single adj.
Single adj.
I have too few miles on the ones on my car to tell you. All I can tell you is I don't like the bump valving much at all, and the rebound adjustment is too wide since it's near useless until you put 3-4 sweeps in to the shock...
I am not that pleased with how the adjustment is made. They don't even give you a tool. I made my own adjusting "pins" out of a steel punch & a couple of allen wrenches, grind down the ends to fit the adjuster hole.
I faced the adjust spot front on the fronts & back on the rears so (with a long arm) you can reach in and "swipe" the adjuster. For the front I usually drive up on a piece of wood so it's easier to get under (lowered car).
Very interesting...I have the older 3013 (non inverted) and the compression is less than the stock 01Z shocks they replaced so ride quality actually improved. I am surprised they raised this on the revision, I would not want it.
With full soft setting all around (using my butt o meter) the ride is comparable to the 04 oem shocks I took off. When you crank to full stiff they are pretty rock hard.
I am not disappointed with the shock, so far as control, just the quality problem I am having (bushing movement) & difficult to adjust.
On my c4 I had QA1 shocks & they were quite easy to adjust (twist ****) & worked pretty well soft to stiff.
A very different description can be found in drbenne's thread about the LEMD/HardbarUSA rebuild of his Penske 7500 shocks!
Vetteless
St. Jude Donor '09
I'm still getting used to mine - I have maybe 3 autocrosses on them now. The bump does seem a little stiffer than the '02 stockers I took off. As far as rebound, I have mine set at 4-sweeps front and 2 rear, and that seems like an okay place to start. I don't know that the shocks can or will give you any more absolute cornering grip, but the response when changing direction is dramatically improved.
I haven't adjusted them since I put them on, but I'm confident it will be a pain in the *** when I do.
PS: Since I put them on, I seem to be fighting a throttle-on push that I didn't have before. This should mean I need a little more rebound in the front, right?
You are only adjusting rebound with that, not compression (bump). The bump in the older 3013 was less than the 01-03 shocks, not sure how it compares to the 04 shocks.
Good shocks with good valving should definitely help you achieve better overall grip! Nobody would bother upgrading to the mega-buck shocks if all you needed was a rebound adjuster to help control transistions.
Did you adjust ride-height/corner weights after putting on the KONIs? I found my ride-height increase measurably and it wasn't consistent front-to-rear so it changed the rake of the car... and that could also explain you're new push.
These shocks are single-adjustable for rebound; "rock hard" is a weird way to think of that. :-) I was disappointed in the change I felt from the C6 Z51 shocks (~12Kmi) to the Koni 3013Sports... ultimate grip did not feel much better on track, and as I mentioned the minimum rebound adjustment seems to be in the 3-4 sweep range...
I had the bushings on both fronts slip out at the SCCA Southeast Divisional Championship Finale event this weekend... Pretty damn annoying....Contacted my friend at Koni... we'll see what happens...
