Longest lasting clutch? (Road course & autox)
Old 10-25-2007, 06:34 PM
rickeolis
rickeolis's Avatar
Default Longest lasting clutch? (Road course & autox)
I've had several racing cars now and have tried a multitude of different clutch brands and designs, but haven't found anything that lasts.
I recently used a 'sintered iron' disk which didn't overheat and grabbed hard, but still didn't last very long.
6 pad ceramic pucks grab well too, but last about half as long.
I'm not generally rough on clutches by nature, but racing is simply demanding. So far I believe the stock replacement disk lasts as long as anything I've tried but they do get hot and slip towards the end of a long set of runs.
I've heard kevlar works well too but it doesn't seem very popular.
I'm willing to spend some good money for something I know would work, anyone???
Old 10-25-2007, 07:34 PM
redvetracr
redvetracr's Avatar
have you tried a Quartermaster 7.25" or 5.5" triple disc.....
Old 10-26-2007, 10:45 AM
rickeolis
rickeolis's Avatar
I just saw and ad for the Quartermaster system on a website that caters to stock car drivers. They do look well built, I'll have to ask those guys if they like them.
Thanks-
-Rick-
Old 10-26-2007, 11:03 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
My car has been a dual use car it's entire life... I swapped my stock clutch out in '05 w/ 45k on it simply because the drivetrain was out to repair the rear under warranty. I've got anothe 35k on my Luk stage II w/ fidanza aluminum flywheel and it's holding fine. I don't drag race but I drive the car hard, speed shift often, and run 4-6 hpdes a year.
Old 10-26-2007, 11:04 AM
Cobra4B
Cobra4B's Avatar
I'm curious what others recommend here... when it comes time to do another clutch I'm thinking towards a textralia w/ the aluminum flywheel.
Old 10-26-2007, 11:12 AM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
i have run a luk in our '02 ZO-6 for two years..no problems..i am just replacing an exedy twin disc in the high hp car that went 3 seasons ,and i'm hard on stuff..
will have a report on a triple disc carbon as soon as we finish the install and try it out!!
Johnny
Old 10-26-2007, 11:36 AM
rickeolis
rickeolis's Avatar
I work with John Deere equipment and I see that some heavy equipment uses LUK as the OEM clutch. That can't be bad!
-Rick-
Old 10-26-2007, 02:52 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
LS6 clutch and Fidenza has been fine. Next will be a 5.5' 1/4master after I get a winch on the trailer
Old 10-26-2007, 03:21 PM
rickeolis
rickeolis's Avatar
Those Quartermasters look like the right thing, but OMG, my tranny doesn't cost that much!
Still, if it outlasts 3 other clutches, I'm money ahead...
-Rick-
Old 10-26-2007, 06:30 PM
redvetracr
redvetracr's Avatar
If anyone is interested I have a brand new 7.25" AP racing triple disc with QMI discs (QMI is a direct copy of the AP)...all you need is the correct "button" flywheel. $400+UPS owns it
redvetracr
To Longest lasting clutch? (Road course & autox)
Quick Reply: Longest lasting clutch? (Road course & autox)
