Need Urgent help with Sharkbar Install - Sunday
I know this is a strectch but I started an install without checking all my paperwork and I have everything disassembled and went to cut my panels and the template is missing I checked the Vetteworks site and they have install instructions online but not the template.
I was hoping someone might have a copy of the template they may be able to scan and e-mail to me? I don't have a fax machine at home
Thanks,
Paul
Thanks,
Paul
Thanks,
Paul
Thanks,
Paul
I would let you fax it to me and I would scan it but the fax has no carbon in it as it kept sticking. I need to get some tomorrow but it may be a option for someone else to help.
I can see you guys are working to help and I really appreciate the effort. It looks like now I will just contact Dan tomorrow and see if he can send it to me.
I've got the brackets installed and everything is ready just to cut the holes, feed the bar through and attach it then get the panels back on.
I did get my oil catch can installed while I waited so the day didn't go to waste.
Pcervone,
Be careful, copies do not always delicate correctly. The Vetteworks template has to be perfect or the holes will be off and the grommets will not fit. This is why they're not on the web page. I will send you an original tempete tomorrow.
Dan
Vetteworks
www.vetteworksonline.com
253-223-4968
Dan
Vetteworks
253-223-4968
Pcervone,
Dan
Vetteworks
253-223-4968
Dan
Vetteworks
253-223-4968
Paul
