Racing Brake vs. Carbotech...no comparison
Old 09-11-2007, 09:57 PM
Gary2KC5
Gary2KC5's Avatar
Default Racing Brake vs. Carbotech...no comparison
Fact: The C6Z06 eats brake pads like they do hot dogs at an eating contest. Unless you pony up $4k+ for a BBK you are gonna go through pads and rotors.
Racing Brake looked like an alternative to Carbotech at about $100 less/set. Their participation and posting in discussions helped sway me into trying there stuff.
I have held back from posting since my 1st track event in April until now because I wanted to give RB a fair shot. I had some very bad results on that 1st event and RB stepped up to the plate with refunds and they paid for me to replace calipers, SRF, gave me a good discount on a set of 2P RB rotors, recalled the pads (giving those with knowledge or email adds refunds on the pads too), and they developed better (in theory) pads, and they gave me a set to test. I have no complaints with their efforts or customer service.
I'm an aggressive, late braking driver with laps times at Road America around 2:30-2:32, so this is only my experience...your results may vary.
April - Road America, RB ET 700's stock rotors. Front pads were completely burnt off the backing plates in less than 12 laps (1 and a half sessions). resulted in major carnage to the front brake system.
June - Autobahn CC, RB ET 900's RB 2P front rotors. Only got 5 laps in on the full course over 2 session and was learning the south course. pads wore 2 mm and the 2P rotors were groved in just 5 laps.
Sept. - Road America, RB ET 900's RB 2P front rotors (from previous event) pads worn down to the backing plates in 2 full sessions, about 16 laps.
Remove RB 2P rotors, put on stock rotors and a new set of Carbotech XP12's and kept the RB 900's on the rear (as the C6Z06 does little braking with the rear*)
Carbotech's had much better torque and stopping power and they lasted 3 and a half session...exactly as they did last year @ RA.
I still had to put yet another set (Carbotechs) on the front to finish the event but I have to say they perform better and last much longer than the RB stuff did.
Just my comparison with the 2 brands I've used...
And yes there will be a BBK in my future...I'm tired of changing these stupid padlets before the event and twice during
*BTW: the ET 900's I kept on the rear were also worn to the backing plates by the end of the week end.
Old 09-11-2007, 10:12 PM
rudyarias
Support Corvetteforum!
rudyarias's Avatar
You may find that the CarboTech one piece pads for the C6Z06 (J56) brakes will last longer but do not have the brake torque the individual pads produce. As far as the longevity of the CarboTech C5 vs the J56 Pads. My experience has been the same for both at Road America and Blackhawk Farms. Both tracks rank hands down as the most brutal on brakes.
I too tried the Racing Brake pads because they are a mm thicker than the CarboTechs. I was not happy with them as well. The only brake pad I found that out lasted the CarboTechs were the Cobalt Technologies pads which like the CarboTech are ceramic but produce a better brake torque.
Old 09-11-2007, 10:33 PM
levettegrl
levettegrl's Avatar
Cruise-In IV Veteran
I have been running Carbotech's on my C5 for a few yrs now and can honestly say I would be hard pressed to find a better pad
Old 09-12-2007, 02:35 AM
0C5stein
Former Vendor
C5stein's Avatar
We have customer's with similar results as you describe. Some of the brake experts that i have spoken with say that a great deal of the problem lie with the release charecteristics (or lack there of) of the stock C6Z Caliper. It seems that many times the brakes do not release completely and that causes intense heat in the pads, Calipers & rotors.
Two of our customers have experienced lower operating costs running the Baer Ext+ as their pad and rotor wear have declined dramatically, while increasing their braking performance a great deal. While we did experience a slightly lower softer pedal,we believe that we have a complementary master cylinder upgrade that will make for a more 'comfortable' pedal.
I've seen test results that shows that the Baer Caliper is the stiffest in it's (below $3000ish) price point. The other 'non-monoblock' calipers are only as stiff as the bolts holding the two halves together. These Baer Calipers are machined from a solid forged aluminum billet. The only other calipers on the market that are this ridgid are by PFC, Alcon and AP and cost much more.
Old 09-12-2007, 04:18 AM
BQuicksilver
BQuicksilver's Avatar
Cruise-In III Veteran
I'm not sure what compounds are out there for the C6Z, but IMO none of those pads are wearing long enough. XP12's were the worst pad (by far) I've ever used in terms of longevity.
Old 09-12-2007, 07:22 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Gary you should post it in the Z06 section also so people don't fall to the hype if you didn't already.
Old 09-12-2007, 09:32 AM
Gary2KC5
Gary2KC5's Avatar
good point John, I will post a link to this thread.
Old 09-12-2007, 01:21 PM
greendot
greendot's Avatar
Thanks for the info. I was on the verge of getting some 700's. Now I'm not sure what I'll do
Old 09-12-2007, 03:17 PM
95jersey
95jersey's Avatar
I used their pads (RB) with some success, but the bottom line is that no matter what pad company you go with, your not getting more than 1 or 2 events out of a set of front pads.
To compensate, I learned to modify my braking with lighter pedal pressure. So instead of just mashing the brakes like I would with my C5, I apply a medium pressure and back up my zone just slightly. I find that the pads last much longer and you don't sacrafice a lot in performance. So after a year with this car, I learned that if I mash the brake pedal in every corner, you run out of pad fast. Since each paddlet has a piston, if you mash them into the rotor, you just accelerate wear and really don't get better braking.
I am going to try the big brake pad next and see how it goes, but a BBK kit is probably going to pay for itself if you plan to own this car in the long term.
Old 09-12-2007, 03:31 PM
Gary2KC5
Gary2KC5's Avatar
I did try to do some lighter pedal modulation and it seemed to work. I just need more practice...It's hard to think about lighter pedal modulation though when your pushing a buck sixty into a 45 mph left hander though.
Old 09-12-2007, 04:05 PM
John Shiels
Don't worry Gary just get some good tires and they will hold you in the corners!
Old 09-12-2007, 08:21 PM
Z06 Whisperer
Z06 Whisperer's Avatar
HA HA Yeah Gary and I were in the same run group this past weekend and he would come zooming by me!
Hey I just thought of something--maybe I can blame my abs failure on him--you know 'cause I was trying (desperately ) to keep him in sight after he passed me during the second session and my brakes crapped out.
Seriously folks, he does MOVE out there!!
I really thought the classroom sessions given by that CART test driver were among the best I'd heard at one of those events. You were asking good questions too (and I was pouting because I could not try out some of the techniques he recommended).
(I really need my editor here before I get too long winded , but I have to tell you all quick about the CART driver's name and a goofy story that goes with it--pay attention John it concerns you LOL)
Back at the PCA event in Aug at RA, one of the BMW organizers came by to chat and says, "Guess what, Shields is here!!". Dan and I both turn to each other and I know we're both thinking the same thing--that it's John Shields that's at the event. Well major LOL It turns out the CART test driver is named Shield Bergstrom. And he was the same classroom instructor at the BMW event this past weekend!
Thanks for the brake pad comparisons write-up Gary!!
Old 09-13-2007, 12:22 AM
Gary2KC5
Gary2KC5's Avatar
Anita, thanks for lending a helping hand while I was changing pads...I probably was not at my best...something about putting a 3rd set of pads on for the week end.
Hey that is one FLAT spotted tire.
Old 09-13-2007, 12:25 AM
Gary2KC5
Gary2KC5's Avatar
Maybe some NASCAR bankning in some of those 90 degree turns @ RA...Then the Indy Cars could lap the 4 miles in under a minute
Old 09-13-2007, 09:38 AM
95jersey
95jersey's Avatar
One thing I notice about the new Z's brakes, is that pushing the pedal to the floor doesn't improve the braking, just wears down the pads faster. I don't know if this is because the Z's brakes actually do a good job of putting a good amount of torque higher in the pedal arch than the standard C5, or that they just totally suck in everyway!
It is really ashame that after spending $70k on a car, that you have to even deal with issues like this! I didn't feel so bad putting $1500 Wilwoods on a $40k C5, but I am pretty pissed that I have to buy $3k BBK on a $75k car!
GM are you listening?
Old 09-13-2007, 10:05 AM
John Shiels
they just suck! 3 grand only does the front
Old 09-13-2007, 02:28 PM
Gary2KC5
Gary2KC5's Avatar
To Racing Brake vs. Carbotech...no comparison
Old 09-13-2007, 10:27 PM
vms4evr
vms4evr's Avatar
You know it really sucks that we can't get some GM Engineers involved in this forum. Especially the ones from the race teams who have input back into the cars design. Not just this C6 Z06 brake issue.
Some in this section are hard core and push the car to its limits. We have T1 racers. Many do DE and/or TT and push hard even if not 10/10ths and we still find some serious issues that could help build a much better car. My C5 Z06 is pretty damn good and I have few complaints. But it sure would be nice to have some of those engineers on here to listen and offer us suggestions and advice based on what they know. I'm sure some information could be shared without them giving away big trade secrets. In the long run it would benefit both sides of the game. After all we ARE customers and we ARE running these cars like they are supposed to be capable of being driven.
It really is a shame.
Old 09-14-2007, 12:00 AM
rudyarias
rudyarias's Avatar
Every GM engineer who races and works at Milford that I spoken with loves the C6 Z06 brakes.
Old 09-14-2007, 01:19 AM
fhturner
fhturner's Avatar
I'd have to agree with this. I mean, holy sh*tballs...are you kidding me??? Gary, you actually had to swap pads out after ONE DAY??? That'd be ridiculous enough to make me consider hanging it up if a $360 set of pads (Carbos on my C5Z) couldn't last through half of an event! And I'm sure the C6Z stuff is more expensive than that. That's atrocious!
Fred
Quick Reply: Racing Brake vs. Carbotech...no comparison
