What tap/die do I need for C5 wheel studs/lugs?
1 Post
Cruise-In II Veteran
It is a real PITA to change them, but I did when I had everything apart for the Pfadt urethane bushings. I used ARP 2.5 inch long GM 12mm and cut them down to 2 inch (under the head). As you said, the rears are not easily servicable but at 2 inch long, (but not at 2.5 inch) the fronts are replaceable. I cut mine on my lathe, but with a hex die or nut that is split, it makes a nice clamp in a vice for a saw that cleans the thread as you turn it off.
having a die to clean a "buggered" stud is handy - it will save a paddock replacement or the end of the day....
A tap is not needed - carry spare lugnuts and heave the buggered ones...
