catalytic converter blow out?
Old 08-25-2007, 03:37 PM
anotherone
anotherone's Avatar
Default catalytic converter blow out?
Recently did sebring and flogged the begeevers out of my stock 06 c6 coupe. It was 97 air temp and all was ok until turn 16 when the car shut down. I restarted it and limped back in to pit and let it cool down although I had no dic warnings. Tried it again a little later and it happened again with check eng light coming on.
Making a long story shorter the dealer said I blew out both my catalytic converters. Has anyone experienced this before and is it preventable? I searched and couldnt find squat on the forum!!!!!
Old 08-25-2007, 08:15 PM
rudyarias
Support Corvetteforum!
rudyarias's Avatar
You should have gotten a flashing engine light if you were blowing the cats. If the cats were blown out, it should be covered under the mandated warranty on the emissions in your car.
Old 08-25-2007, 08:29 PM
anotherone
anotherone's Avatar
dealer didnt balk at all ; they are super and treat me like the owner of the place. I had no warnings at all until it shut down ; of course I was really concentrating on the line. It just seems weird.
Old 08-25-2007, 09:13 PM
rudyarias
rudyarias's Avatar
My engine light kept flashing indicating that the cats were not working properly (being contaminated). It turned out that nbr 7 cylinder blew from detonation (bad injector) and the excessive unburned fuel blew out my cats. My dealer bend over backwards to get it covered under warranty.
Old 08-25-2007, 09:25 PM
anotherone
anotherone's Avatar
thanks for that info; will know more when the parts are in mon or tues. I will post the final repair info.
To catalytic converter blow out?
Quick Reply: catalytic converter blow out?
