Track Brake Pad Change
For the first time I had to change brake pads at the track. My question is how do you properly bed them at the track. At home I follow the StopTech procedure (although I am paranoid ever time I do it-my car is loud & I picture myself explaining to the local gendarme-sorry sir but I was just bedding in my race pads, I am sure you understand!?!?!).
Thanks, Geoff
Thanks, Geoff
You can bed thenm at some tracks if they have room like VIR or find a decent road that is empty. You only need to do 65-70 to bed pads and season the rotors.
My question is, is this a good break in (or is that brake in??) or should I do something different?
Thanks, Geoff
just go out and drag them around the paddock as good as you can. It will not be as good as going out on the highway and doing the 20 stops, but it will work. If it is rear pads, you can jack the car up and use the engine and brakes together to heat them up. Just remember to shut down the AH/TC.
I've had to do emergency brake swaps just before a race, and even dragging the brakes hard for 1/2 a warm up lap (with the other 1/2 to cool down) can get enough mechanical wear on the pads to get a good mating surface between the pads and rotors. Again, not ideal, for it's fine.
Track time is expensive but since I can't bed pads on the street, I force myself to take the first session in my spring test day to bed in 3 sets of pads.
Walking into the trailer and seeing 3 sets of pads ready to go is a very comfortable feeling.
What pads do you run? I just did 10-20 stops from 65-70 at VIR and it was enough to thurn the rotors blue a Stoptech recommends. I have never had a big issue running Wilwood pads new at the track. I use some sense the first few laps.
Good advice guys I appreciate it.
Geoff
