*** ECS Oil Cooler Adapter ***
St. Jude Donor '05-'08
The oil cooler adaptor (with provisions for stock oil temp sending unit machines into it) can be used for any type of oil cooler you wish to use, it comes complete with hardware and a new gasket.
We designed it to work with the Dewitts rad/oil cooler combo, but it is a universal adaptor so use it as you wish. It has also been tested with different headers so that is not a problem either.
The fittings are AN#10 and if your application needs additional 1/8th inch fittings (for a turbo etc) we can do that for you at no additional charge.
Price is $139.00
Price is $139.00
