Camera mount options w/o harness bar?
Are there any viable camera mount options with having a harness bar? Doing VIR in 2 weeks and would like to mount video camera. The one from my TA that mounts to passenger head rest will not work in Z. Suggestions and links.
Thanks.
Thanks.
Vetteless
St. Jude Donor '09
I used one of these for a couple years before I put my crossbar in - worked pretty well as long as you make sure it's stuck on good.
http://solotime.com/index.asp?PageAc...ROD&ProdID=302
Hope that helps!
Hope that helps!
Did you hang that off your body or put it on the roof? That would be some cool video. Seems like a temporary fix until I get the bar. Thanks.
Vetteless
St. Jude Donor '09
Here's a video I shot with this mount a while back - you can see the camera moves around a little, but not bad at all.
