street vs race pads, same rotor
Old 07-20-2007, 04:25 PM
mousecatcher
mousecatcher's Avatar
Default street vs race pads, same rotor
For a dual-use car (HPDE and street), would I need to re-bed the pads whenever I swap race/street pads? Or only when a brand new set of pads is installed.
Old 07-20-2007, 05:23 PM
Z06cool
Z06cool's Avatar
Whenever I swap out, it feels skiddish until I do some 30-60mph runs to re-bed.
Old 07-20-2007, 10:00 PM
z06jones
Support Corvetteforum!
z06jones's Avatar
Yes.
Old 07-21-2007, 10:42 AM
c4cruiser
c4cruiser's Avatar
I recall reading a couple years ago here that Hawk street pads and some of their race pads share some of the same compounds. If you switch from say HPS pads to HP+ or Blacks, the idea was that you should not have to bed the new pads as long as you don't change the rotors.
Not sure if that applies to other brands of pads where street and race-level pads are swapped.
But it's still a good idea to make a few medium-speed stops and then let the brakes sit for 15 minutes without use.
To street vs race pads, same rotor
Quick Reply: street vs race pads, same rotor
