Anyone run 305 or 315 tires on 10" rims in front?
Old 07-09-2007, 11:18 PM
Dr Chill
Dr Chill's Avatar
Default Anyone run 305 or 315 tires on 10" rims in front?
Would like to know about any experience with this setup. Thanks.
Old 07-10-2007, 09:16 AM
XPC5R
XPC5R's Avatar
Those sizes really like about a 10.5" to 11" wheel as a minimum, the wider wheel improves steering response nicely. I'm running mine on 12" wheels now (315 Hoosiers) and they are sticking great.
You will get some fender rubbing if the car is low, as well as possibly rubbing on the wheel well and a-arm at full lock, those tires are wide.
Old 07-10-2007, 09:18 AM
UstaB-GS549
UstaB-GS549's Avatar
I'm pretty sure all the T1 racers run 315 on 10" up front.
Old 07-10-2007, 09:52 AM
rasrboy
rasrboy's Avatar
Why yes we do! They work just fine!
Aaron
Old 07-10-2007, 10:29 AM
wtknght1
wtknght1's Avatar
Yea verily we do! Works great...no issues. If you are running the DRM brake ducts, ensure you don't turn the wheels to lock!!!!
Old 07-11-2007, 10:44 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
I have one friend running C5 Z06 rears up front with 305's on an 03Z and it works well but it does rub the fender a bit. He has T1 bars with stock springs for now and runs 2 degrees negative camber. But there is a little rub, nothing to worry about (they'll scalp themselves).
Old 07-11-2007, 12:38 PM
yakisoba
yakisoba's Avatar
I have run 315 Goodyear tires on a GS front rim. It's a squeeze. You really don't get the whole tire on the road, because of sidewall pinch. The Goodyear DOT R compound tires seem to fit better on smaller rims than, say, Kumho. It would work fine on a 10" rim, I'd think. I much prefer to run 295s or 275s on my rims.
To Anyone run 305 or 315 tires on 10" rims in front?
Quick Reply: Anyone run 305 or 315 tires on 10" rims in front?
