What brake pads do you auto X guys use?
Old 07-09-2007, 05:58 PM
YO-EL
YO-EL's Avatar
Default What brake pads do you auto X guys use?
Drag racer here:
I need something that is REALLY going to hold me at the line when I foot brake it..
It was recommended to me auto cross guys might know what really works..
Ellis
Old 07-09-2007, 06:22 PM
TedDBere
TedDBere's Avatar
Either Hawk HP+ or the stock pads will bite when cold.
Old 07-09-2007, 06:26 PM
wallyman424
wallyman424's Avatar
uhm. foot braking means being stationary and applying throttle right?
Thats static friction between the pad and the rotor, I'm not entirely sure if a different pad will be any better at providing static friction.
I could be wrong though.
Old 07-09-2007, 07:18 PM
c4cruiser
c4cruiser's Avatar
Are the front wheels turning or are the tires sliding?
If you are running a line lock and the front wheels are turning agains the hot sticky rear tires, you may need more pressure at the front brakes.
Old 07-09-2007, 08:51 PM
mikahb
Vetteless
Support Corvetteforum!
mikahb's Avatar
St. Jude Donor '09
Hawk HP+ here too, but
Maybe a proportioning valve cranked all the way front-biased is a relatively easy fix?
Old 07-09-2007, 09:40 PM
YO-EL
YO-EL's Avatar
when you foot brake it, wouldn't all 4 brakes front & rear be applied?
So what would hold me if I want to tach it up to say 2500-2800 rpms?
Old 07-09-2007, 09:46 PM
wallyman424
i dont really get what you're saying with foot braking...
are you doing a standing burnout, or are you running an auto and preloading the torque convertor?
what were saying is that better brake pads will slow a spinning rotor quicker, however the static friction coefficient is likely the same/similar when compared to all pads.
i would think a higher stall tq converter would be the way to go. wouldnt it?
Old 07-09-2007, 10:23 PM
Allthrottleandsomebottle
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Ellis,
Z06 pads work fine......drag, AutoX or road race. Multi-purpose pad for my multi-purpose 97'
Old 07-10-2007, 10:07 AM
YO-EL
YO-EL's Avatar
Just preloading the converter at the starting line..
I use a line lock for burnouts..
Old 07-10-2007, 10:52 AM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,079 Likes on 653 Posts
For a second I thought you were going to try turning that thing for a change.
Most race type pads work worse when cold, put a Trans brake in there and be done with it.
Old 07-10-2007, 01:08 PM
XPC5R
XPC5R's Avatar
Wilwood H's here all the way around. They have more cold and hot bite than the stock compounds (they are close to the highest friction pads wilwood has), so should do what you need.
To What brake pads do you auto X guys use?
Quick Reply: What brake pads do you auto X guys use?
