New lap and sub bellt bar from Hardbarusa/Vetteworks
1 Post
Cruise-In II Veteran
We are proud to offer the best lap and sub belt bar on the market. It solves all the issues for C5's and C6's. It is a joint effort of Hardbar and Vetteworks and offers a solution for everybody regardless of what harness bar you have. Wow, imagine two Corvette vendors actually cooperating for the benefit of all…what a concept! The bar is laser cut steel, with custom inserts for the eyelets. It offers full seat travel, clip in lap belt attachments, and positions for your sub belts. It requires no modifications, simply lift the rear of your seat, drop it in, re-attach the stock nuts, attach your belts and you are done. And as a $25 option you can now use it with other brands of harness bars that have down tubes or struts. For the users of BK, RD, bars etc, you now have a proper lap and sub belt mount with the pickup points at the correct angle and position. To do this, we use one of our custom 17-4 PH stainless steel thread adapters that are used with our seat rail kits that are used as a substitute for the nut. Now the foot on the end can go over the stud extension and with the provided washer and nut you are done (the foot hole needs enlargement to 14mm dia.) The lap bet bar is powdercoated black for $150 each side and the stud adapter is $25 each. Available from Hardbarusa.com and Vetteworksonline.com
St. Jude Donor '05-'08
Nice job Gary. I am going to call you tomorrow because the sport seats are coming out and I am going with race seats. I like to have a few ideas from you to see what I can fit with your rails.
thanks
Bob
thanks
Bob
