NAPA Rotors on track??
Old 07-06-2007, 10:57 AM
The Bus
The Bus's Avatar
Default NAPA Rotors on track??
I was just getting my C4[ NASA Racing ] for next weekend at Mid Ohio. It appears that I need new rotors. Did I not read here that NAPA rotors are cheap and good enough quality to use. Need answer ASAP so I can order them or if anyone has any useable 13" front rotors that will fit a stock "91" Vette let me know. I can be reached at orawiecs33@comcast.net
Old 07-06-2007, 11:03 AM
larryfs
larryfs's Avatar
C4 rotors are expensive any where you go..........
Old 07-06-2007, 11:06 AM
FasterIsBetter
FasterIsBetter's Avatar
C5 rotors are the ones that everyone talks about that are cheap and good at NAPA. I've used them on my '03 Z and they work just fine, held up well. I don't know if its the same for C4 rotors, however.
Old 07-06-2007, 12:18 PM
Sidney004
Sidney004's Avatar
Larry, I bought my used rotors from you! Are you saying I paid too much!!!!!
Old 07-06-2007, 12:27 PM
jbauch357
jbauch357's Avatar
I run NAPA rotors on my C5 Z06 with Hawk HP+ pads and the entire setup works great on the street/track - also has been holding up quite well thus far...
Old 07-06-2007, 01:53 PM
Jaymz
Jaymz's Avatar
Rudy.. I run the NAPA rotors all of the time. I will go thru a set of fronts in a weekend.
To NAPA Rotors on track??
Quick Reply: NAPA Rotors on track??
