How to balance car when using C5Z06 rear wheels all around?
I know some of you hardcore guys like to run the same size rear tires all the way around the car. I like this idea for a lot of reasons, but getting rid of the stagger is going to screw up the balance of the car, right? If your contact patch in the front gets larger to match the rear, that should produce wicked oversteer. How do you guys compensate for that? Less negative camber in the front? stiffer springs up front? Bigger sway up front?
Thanks!
Thanks!
i along with MANY other guys run 315's all around. The stock setup has a lot of push built in, so running equal sized tires doesnt produce crazy oversteer. If anything it makes the car more neutral.
It'll just take a track day or two to get used to it.
Thanks!
Premium Supporting Vendor
Thanks!
Thanks!
I do run a little bit less camber up front with the 315s, but it isn't that significant. I'd check tire temps with a temp probe and base your camber settings on tire temps.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
Get a set of poly bushings for the front bar and put them in your kit.
If you need a bit more understeer, it only takes 10 minutes to pop them in...
That might be just enough fine tuning to get it back.
I am not one to take out negative camber up front since it can end up chewing up the outside edges of the tires and the Hoosiers don't like that.
CI 3-5-6-7-8 Veteran
A few months back I picked up some 17x11 oem Grandsport wheels w/ 315 V710s all round. I'll be running VIR with them for the first time next weekend.
Before this I was running Hooser RS304s on my oem Z06 wheels. Should be fun.
You would think there would be too much front grip, but it just doesn't work out that way. Even if it does, you can easily compensate with tire pressures and alignment.
I'm running 315/18's all around on C5Z06 Speedlines, and I can really optimize my tire wear by rotating tires all around the car as needed
Plaster: The only rubbing I get is at close to full lock the tire hits my DRM brake ducts a bit. I just tape up the plastic duct and let the tire hit that. Then replace the tape when it gets chewed up.
