Inexpensive wheels to clear 4 piston 14" Brembo front brakes
Old 06-09-2007, 12:10 PM
C6400hp
C6400hp's Avatar
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
Default Inexpensive wheels to clear 4 piston 14" Brembo front brakes
Anyone know? i need to find some inexpensive street wheels that will clear Brembo 4 piston fronts with the 14" rotor on the front of a C6.
Or if anyone knows how big of spacer is required to clear 4 piston 14" with the stock C6 front wheels?
Anybody have a set that will clear the Brembos that are for sale or trade for stock plus $.
I have 2 sets of stock wheels (1 set comp grey, 1 set silver) and tires to sell unless the Brembos will fit with a minimal spacer.
Old 06-09-2007, 02:15 PM
Deleted 07.13.2020
Deleted 07.13.2020's Avatar
When I swiched from stock brakes to brembos, I used 0.5 inch spacer. But I have a CCW wheels.
Old 06-09-2007, 02:25 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
c5Z05 speedline 18x10.5's will clear most big brakes.
Old 06-09-2007, 03:51 PM
C6400hp
C6400hp's Avatar
I just realized i did not specify for a C6
Old 06-09-2007, 03:53 PM
C6400hp
C6400hp's Avatar
I have a set of CCW Corsairs I use at the track and they will clear without the use of a spacer but I am looking for an inexpensive street setup. Which CCW are you using?
Old 06-09-2007, 03:55 PM
MattW_VA
MattW_VA's Avatar
St. Jude Donor '07
Not necessarily true. Mine rubbed a bit (a TINY bit) until I got the T1 suspension, now they do not.
Old 06-09-2007, 04:20 PM
C6400hp
C6400hp's Avatar
C5 speedline 18X10.5? On the FRONT of a C6?
I put some on the back of my C6 and they stuck out like Dumbos ears.
Old 06-09-2007, 04:41 PM
MattW_VA
MattW_VA's Avatar
St. Jude Donor '07
LOL well they do stick out some, I run the C5 Z06 rears all they way around. Oddly, after the T1 susp they rub a tad in the rear where they hadn't before. But again it's just barely...
Old 06-09-2007, 07:36 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
18 " CCW classics with 1/2" spacer clear my Brembo GTs.
Old 06-09-2007, 09:08 PM
C6400hp
C6400hp's Avatar
How do you like the Brembo's
Old 06-10-2007, 01:32 AM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
I like them.
Car seems more stable and consistent under hard braking.
Old 06-10-2007, 06:26 PM
White92lt1
White92lt1's Avatar
These are my SSR's for the track.
My polished Mallets for the street.
no spacers on either.
Old 06-10-2007, 09:55 PM
ZO6-Driver
ZO6-Driver's Avatar
You ever want to sell those Mallets let me know.
Old 06-10-2007, 10:57 PM
C6400hp
C6400hp's Avatar
I like both especially the Mallets. DO they make the SSR's in C6 offsets? Are either of these wheels inexpensive?
Old 06-10-2007, 11:21 PM
Deleted 07.13.2020
Classic
Old 06-11-2007, 03:21 PM
Silverton
Silverton's Avatar
What are the sizes and offsets for those SSRs?
Old 06-11-2007, 04:50 PM
C6400hp
C6400hp's Avatar
Old 06-11-2007, 09:02 PM
ZO6-Driver
ZO6-Driver's Avatar
I'd like to know what sizes those Mallets are and if they still make them.
To Inexpensive wheels to clear 4 piston 14" Brembo front brakes
Quick Reply: Inexpensive wheels to clear 4 piston 14" Brembo front brakes
