Proportional valve with OEM master cylinder?
What can be done to bypass the internal bias valve in the OEM master cylinder so I can use an external proportinal valve for the rear brakes? Or is the only answer an aftermarket master cylinder?
I forget the cutoff year, others will know, but the later c5s are not proportioned in the master, they are electronically proportioned.
For the earlier years, I believe DRM sold a bias spring.
DRM also has a master with a proportioning valve built-in.
http://www.dougrippie.com/drm/brake_components.htm
