Ace Slick Wheels OK for AutoX?
Old 06-06-2007, 03:14 PM
SpudGT
SpudGT's Avatar
Default Ace Slick Wheels OK for AutoX?
Hello,
I have been autocrossing my C6 Z51 (2007) on stock wheels and tires ... the folks running on R compound tires are just spanking me. My driving is slowly improving and I am to the point of wanting to try out some stickier tires. My budget doesn't currently allow for a $2000+ set of forged wheels.
I want to keep things sized as close to stock as possible, does anyone have experiences with Ace Slick wheels?
Front: 18x9.5 +53
Rear: 19x11 +73
Thinking about Hoosier A6 rubber (maybe R6 if that would be better for a 2 driver car):
Front: 245/40 18
Rear: 295/30 19
May also take this setup out for an occasional track day.
Old 06-06-2007, 04:02 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
big tires are expensive... can you fit at 17" wheel on the front of a C6 w/ the Z-51 caliper?
If so most go for aftermarket Grand Sport wheels. I run 17x11 OEM GS wheels with 315s at all 4 corners.
Old 06-06-2007, 04:19 PM
SpudGT
SpudGT's Avatar
I am trying to stay within the SS class rules, which is why I picked everything as close to stock sizes as possible. Finding stuff exactly stock sized is becoming a challenge. I don't know if a 17 inch rim would fit over the Z51 brakes, or if it would be allowed in SS. Sometimes the rules get a bit confusing.
The front A6 Hoosiers are the same as stock, but if I am reading the specs right they are most at home on a 9 inch rim (is the stock 8.5 rim too narrow?). The rears are not even available in the exact stock size.
Kind of funny that the Hoosier A6 tires cost less than the Goodyear run-flats I am running on now.
Any suggestions would be appreciated.
Old 06-06-2007, 04:40 PM
TedDBere
TedDBere's Avatar
I don't think the 9.5 and 11 inch wide rims are stock sizes for a Z51 C6. They'll put you in ASP. FWIW.
Old 06-06-2007, 05:10 PM
SpudGT
SpudGT's Avatar
So it looks like stock sizes are 18x8.5 and 19x10 (which are required to stay in SS). I don't know if Ace Slick come it those sizes, but Factory Reproductions makes several rims in that size.
Hopefully the Hoosier A6 rubber (F: 245/40 18, R: 295/30 19) will be OK on stock rim sizes. I was worried about the width required by the front tire, but maybe I am reading the tire specs wrong (width range versus measured width).
Old 06-06-2007, 07:13 PM
Lancer033
Lancer033's Avatar
you could go the other way and buy some nice bling wheels for the street and use your factory wheels for AutoX
Old 06-06-2007, 07:17 PM
nightboom
nightboom's Avatar
Factory C5 Z06 wheels will clear the front brakes. You could find a set of them fairly cheap.
Old 06-06-2007, 10:40 PM
02impactblue
02impactblue's Avatar
why don't you buy a set of painted c6 wheels. They are stock sizes and the hoosiers will fit on them. They are always forsale on the forum for 300-400. Cheapest wheels you will find.
Old 06-10-2007, 08:39 PM
SpudGT
SpudGT's Avatar
Thanks for all the suggestions.
I think I will try and pick up a set of used stock C6 wheels, failing that I will go for a set of reproduction wheels.
Old 06-26-2007, 12:20 AM
SpudGT
SpudGT's Avatar
Turns out that I couldn't get a set of used wheels in time, so I picked up a set of Factory Reproduction C6Z06 wheels (in stock C6 sizes). Now I like the look of my AutoX wheels bettter than my street wheels, will have to swap that around later.
I wrapped them with Hoosier A6 tires ... what a difference!
Old 06-26-2007, 08:52 AM
c4cruiser
c4cruiser's Avatar
Don't try the A-series for track use. Hoosier has different compounds for autcross tires (A6) and road race R-series (R6). A full day at the track will pretty much ruin Hoosier autcross tires.
To Ace Slick Wheels OK for AutoX?
Quick Reply: Ace Slick Wheels OK for AutoX?
