Adjustable Endlinks - Worth It?
Old 06-05-2007, 10:54 PM
BQuicksilver
BQuicksilver's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Default Adjustable Endlinks - Worth It?
1) Is most everyone running these?
2) Can you corner weight without them?
3) Are they all noisy?
4) Where did you buy yours?
5) Any other advice?
Old 06-06-2007, 07:52 AM
TedDBere
TedDBere's Avatar
1) Is most everyone running these? Yes
2) Can you corner weight without them? Yes, but when you reattach the sway bar you'll set it with preload and your corner weights will be off.
3) Are they all noisy? No
4) Where did you buy yours? Summit Racing
5) Any other advice? Have fun!
Old 06-06-2007, 09:33 AM
VetteDrmr
VetteDrmr's Avatar
Received 1,387 Likes on 742 Posts
Mr. Bere,
I just checked the Summit website and didn't find anything available for C5s: any idea where I should look?
TIA, and have a good one,
Mike
Old 06-06-2007, 12:06 PM
BQuicksilver
Originally Posted by VetteDrmr
Mr. Bere,
Mike
I just found products from MOOG and Energy that didn't quite look right.
Thanks for the advice Ted.
Old 06-06-2007, 12:49 PM
Aardwolf
Aardwolf's Avatar
I got mine from Guldstrand.
http://www.guldstrandmotorsports.com/index.asp
It's nice to not have to replace bushings. I have not gotten the car corner weighted yet though.
Old 06-06-2007, 01:03 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
VBP makes the T1 end links. The big problem is that most heims are 1/2", yet the OEM holes are 12mm. You end up either opening up the control arm holes, or use a bolt that is smaller than the heim is designed for. Either way, you do get some noise.
I recommend running an adjustable on one side, and OEM on the other (ie one adjustable front and rear). This way you way full adjustability, yet less noise. ***you may have to shorten the heim to match the OEM, as the OEM links are quite short.
Old 06-06-2007, 02:17 PM
TommyBoy72
TommyBoy72's Avatar
I have the ones that come with the Addco bar. It is surprisingly quiet. Like David said, I previously bought a pair and put one on the front and one on the rear but both on the same side of the car so I could remember/adjust both in one jacking. My class does not permit me to change the rear so I have the stock plastic ones...
Old 06-06-2007, 04:49 PM
TedDBere
TedDBere's Avatar
Mr. Bere,
Mike
Now that you mention it, mine came with my front bar, which I ordered from Summit. Sorry.
Old 06-07-2007, 01:07 AM
RAFTRACER
RAFTRACER's Avatar
Tommyboy....you can update to the '02-later sway bar endlinks....the parts catalog superceedes to the later model, significantly better,end link.
FWIW, I have been very happy with the Addco endlinks.....1/2 fasteners require slight control arm burr removal from the factory bolts being tightened and large loads being applied. The VBP endlinks are nice , but the Addco's have nicer built in spacer, and better nuts for the fasteners. The VBP nuts are very shallow and periodically strip when tightened.
Old 06-07-2007, 01:56 PM
TommyBoy72
TommyBoy72's Avatar
Good to know, I was trying to find something to discover if that was the case and legal for SS. Thanks Danny.
To Adjustable Endlinks - Worth It?
Quick Reply: Adjustable Endlinks - Worth It?
