rear end gear
Old 06-03-2007, 11:44 PM
danswofford
danswofford's Avatar
Default rear end gear
What rear end gear would I use to make 4th at 6400 RPM 125-130 MPH in a 02 C5Z
Old 06-04-2007, 06:24 AM
AU N EGL
AU N EGL's Avatar
Well a 3.42 gear at 6500 is appox 150 mph.
a 3.73 at 6400 is approx 139
a 3.90 at 6400 approx 130
Old 06-04-2007, 12:53 PM
danswofford
Thanks for the info in my post about rear end gear. Is there a online calculator somewhere that would calculated speeds in different rear end gears and different trans gears?
What I'm trying to decide is a rear end gear change for my home track of Thunderhill. The 3.43 is just too low. I'm coming out of thrn 11 in 3rd at RPMs as low as 3200. At the end of the straight I'm at about 122-4 MPH in 4th. I think a 3.90 would be about right for the top end but I'd like to see how the 3.90 would work coming out of the slower turns.
Dan
Old 06-04-2007, 03:15 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
down shift to second
To rear end gear
Quick Reply: rear end gear
