Nicks on OEM leaf spring - reason for concern?
Old 06-02-2007, 04:01 PM
roushraven
Coolest Guy Evar!
Support Corvetteforum!
roushraven's Avatar
Default Nicks on OEM leaf spring - reason for concern?
I replaced my OEM Z leaf springs with Hypercoils and found some nicks on the top surface of the front OEM spring. I have no idea how 9or when) it could happen given the location as mounted on the car (top of the spring facing rear).
Anyway, look at these pictures and tell me if there is any reason for concern about the nicks? I want to sell the springs with confidence.
By the way, the fibers are from the cloth I used to wipe down.
-RR
Old 06-02-2007, 04:57 PM
davidfarmer
davidfarmer's Avatar
just keep an eye on them. Remember, when loaded, the tops of the springs are in compression, and the bottoms in tension. Almost all structures are stronger in compression, so you should be fine, at least for now.
I'd be much more concerned if the damage was near the bottom edge.
Old 06-02-2007, 11:06 PM
roushraven
Coolest Guy Evar!
roushraven's Avatar
Thanks, I guess with that in mind I really shouldn't sell them.
-RR
Old 06-03-2007, 01:11 PM
kelp
kelp's Avatar
The cut on the right looks real bad.
Old 06-03-2007, 05:35 PM
davidfarmer
no I wouldn't sell them, although I would dab a little polyester resin in and put them back on if you go back stock someday. They'll last for an eternity on a street car.
Old 06-03-2007, 05:49 PM
roushraven
Coolest Guy Evar!
roushraven's Avatar
Thanks for the tip, I'll do that then wrap them up and stick them down in the basement with the other stock parts I have.
-RR
To Nicks on OEM leaf spring - reason for concern?
Quick Reply: Nicks on OEM leaf spring - reason for concern?
