FS: Red/BLK Corbeau FX1 Pro Seat W/ Slider
I've got 1 Red and Black Corbeau FX1 Pro Seat mounted to the Corbeau slider/bracket. Here's a quick link to what the seat looks like: http://www.corbeau.com/products/fx1pro/fx1pro.shtml# , and I can get any detailed pictures if needed. The seat is in great shape. The bracket/slider is shown here: http://www.corbeau.com/products/bracket/bracket.shtml
I can sell the complete setup for $290 + shipping. Or I'd be willing to meet someone to help out. I'm located in Tyler, Tx.
I've also got some track wheels and RA1s for sale if anyone needs a good set.
-Joe
-Joe
no thank you on the wheels. very interested in the seat/slider though, how difficult is install? simple mount or cutting/adjustment required? how old is the seat and why are you selling it?
I can uninstall my factory seat, then install the seat in my car in under 9 minutes. The process is as follows:
1. take off the front plastic covers that cover the 15mm bolts
2. undo and take off the two front 15mm bolts
3. slide seat forward, undo and take off the rear two 15mm bolts
4. lift the seat up slightly and undo the factory PS wiring harness
5. take seat out of car
6. take off the safety belt latch using a 18mm socket and undo the small wiring harness attached
7. put the new safety belt latch on the new seat using the same latch and same bolt
8. put the seat in the car
9. put on and torque down all four 15mm bolts
10. get in the car and adjust the slider to where you want to sit
11. start car and have fun!
No cutting, welding, modifying whatsoever.
I'm selling it bc I'm selling my car. I will have no use for it driving a Z71 truck.
