Was I supposed to use some sort of sealant on new OEM bleed screws?
Old 05-17-2007, 11:01 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default Was I supposed to use some sort of sealant on new OEM bleed screws?
I just finished up installing new oem calipers and fresh bleed screws... I just screwed them in as they came.
Now I remember that the speed bleeders I used to have has sealant on them.
Old 05-17-2007, 11:22 AM
Falcon
Falcon's Avatar
I've changed bunches of them and have never put sealant on them.
Cobra4B
Cobra4B's Avatar
^ Thanks man... just wanted to double check.
Old 05-17-2007, 11:26 AM
freefall
freefall's Avatar
agree - nothing needed.
Old 05-17-2007, 11:33 AM
Aardwolf
Aardwolf's Avatar
The speedbleeders have the special sealant for when you bleed them. You turn them open then the sealant is to not let air in while the fluid goes out. If you use them a lot your suppose to put more sealant on. Just FYI why the speedbleeder has it and stock does not. Most times if you get a stock part, it will have sealant on it if it is needed.
Old 05-17-2007, 01:49 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
It is a compression joint....ie the taper is the seal, NOT the threads. OEM style bleeders, like AN fittings, don't require the threads to seal.
Old 05-17-2007, 01:50 PM
Cobra4B
Cobra4B's Avatar
^ Cool thanks... that's what I figured. Just double checking and being **** about the brakes.
To Was I supposed to use some sort of sealant on new OEM bleed screws?
Quick Reply: Was I supposed to use some sort of sealant on new OEM bleed screws?
