Rear brake pads very tough to get in... will I have pad dragging issues?
Old 05-11-2007, 09:14 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default Rear brake pads very tough to get in... will I have pad dragging issues?
Got some fresh calipers and brackets powdercoated from Jason (Cajundude) @ Gulf Coast Performance.
Today the rear pads were very tought to get in place.. Will I have pad dragging issues? Or you think they'll loosen up with use?
Should I grind the pad backing plates until they slide in/out w/ ease?
Old 05-11-2007, 09:29 PM
Bimota Guy
Bimota Guy's Avatar
Were you unable to push the piston in farther?
Old 05-11-2007, 09:39 PM
Cobra4B
Cobra4B's Avatar
They're new calipers... the issues is where the "ears" on the pad backing plates fit into the caliper bracket. The added thickness of the powdercoat made them very tight to pop into place.
2 of the pads wouldn't even go so I had to grind the packing plate "ears" a little.
I'm wondering if they bing in there tight will prevent the pad from comming off the rotor surface when the pedal is released.
Old 05-11-2007, 09:44 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Grind the extra powder coat off the mounting ears.
Randy
Old 05-11-2007, 09:47 PM
TedDBere
TedDBere's Avatar
Why didn't you just scrape the paint out of the grooves instead of grinding down the tabs?
I doubt you'll have an issue with the pad dragging. You'll certainly notice it if you do as you leave your driveway, if it's sticking on the rotor.
Darn, you beat me to it Randy. lol
Old 05-11-2007, 11:36 PM
Cobra4B
Cobra4B's Avatar
Randy
Thanks guys... I didn't even think about the issue until I had it all together. I was simply concerned about getting the pads in.
They're only tight on the rears for some reason... I can either use my bench grinder to grind the pads some more, or I can take my dremmel to the PC.
I'll probbaly do the latter. We'll see.
Old 05-11-2007, 11:46 PM
Cobra4B
Cobra4B's Avatar
Eh... just went out and looked at it... grinding off the PC has the potential of making the brackets look ugly if I don't do it perfectly (yes I'm part waxer).
I'll just pull the rear pads and bench grind the ears a smidge more.
Old 05-11-2007, 11:48 PM
Cobra4B
Cobra4B's Avatar
See how pretty!
Old 05-12-2007, 11:25 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
grind the ears, pretty common problem.
See you've got new bleeders....hope they didn't paint down inside of the bleed holes....
Old 05-12-2007, 11:44 AM
Aardwolf
Aardwolf's Avatar
When you bed the pads they will wear down a little to.
Old 05-12-2007, 11:58 AM
Cobra4B
Cobra4B's Avatar
Bleed holes, brake line holes, and slide pin holes were all sealed off perfectly.
Old 05-12-2007, 12:27 PM
Cobra4B
Cobra4B's Avatar
Well that took all of 5 min w/ my bench grinder
Old 05-12-2007, 07:16 PM
gonzalezfj
gonzalezfj's Avatar
Make sure there is some play between the pad and the caliper when cold. Pads get hotter than the caliper and differential expansion can lock the pad in the caliper. result: No braking in that caliper or dragging pad in that caliper.
Frank Gonzalez
To Rear brake pads very tough to get in... will I have pad dragging issues?
Quick Reply: Rear brake pads very tough to get in... will I have pad dragging issues?
