New Caravaggio Races Seats Installed and NO codes
Old 05-09-2007, 05:07 PM
JDIllon
JDIllon's Avatar
Default New Caravaggio Races Seats Installed and NO codes
I just finished installing the new Caravaggio race seats it took about 2.5 hours for the drivers side and 2 hours for the passenger side. The instructions were pretty good but you have to figure out a few things for your self. Not bad I only took both seats out twice before I got it right, call me if you decide to install these, I can save you a lot of time. All of my belts fit the same as the std. seats. You get forward and back and tilt on the drivers side (Z06) and he gives you the instructions and the jumper for the side air bags. They fit great, I am 195LBS, 5'10" tall and a 38 waist alittle snug but not bad. The other stuff is Sharkbar and 6 Pt. G-force belts. As for as weight the stock seat that you take out weighs a bout 26LBS and the Caravaggio is16 so you save about 10 per side. My scale may be off pound of so. JD
Old 05-09-2007, 05:23 PM
sefa01
sefa01's Avatar
St. Jude Donor '09-'10
Nice job, Jim. They look great. I'll look forward to seeing them at VIR.
Old 05-09-2007, 05:42 PM
JDIllon
JDIllon's Avatar
Thanks Steve, I look forward to seeing you again at VIR also. Have a great summer and if you get down this way give me a call. JD
V8 Juice
Support Corvetteforum!
V8 Juice's Avatar
Jim,
I didn't think your car could look better, but the seats add to the appearance and upgrade the harness system. Mine haven't arrived yet, but will contact you when they do.
Art
Old 05-09-2007, 08:30 PM
Z06cool
Z06cool's Avatar
Very nice....
Old 05-09-2007, 08:49 PM
Black C5 Z06
Black C5 Z06's Avatar
O man, how I wish I had the money to get some of these!
Old 05-09-2007, 08:53 PM
Dr Chill
Dr Chill's Avatar
Gorgeous. What do those seats cost?
Old 05-09-2007, 08:58 PM
Black C5 Z06
I hope this link works.
Looks like about $1300 per seat
http://www.caravaggiocorvettes.com/d...rice_Guide.pdf
Old 05-09-2007, 09:09 PM
JDIllon
JDIllon's Avatar
Yep $1295.00 plus shipping, but worth everypenny to not have to worry about all the electric stuff. And they do look great if I do say so my self. The workmanship is really beautiful. These are the ones that John recomends for street and track because they have lower sides than the GT seats so they are easier to get in and out of. JD
Old 05-09-2007, 09:15 PM
Black C5 Z06
Well, since they're so awesome, can I have a donation so I can test them out also?
Old 05-10-2007, 12:02 AM
TooManyIDs
TooManyIDs's Avatar
How comfortable for street use?
Old 05-10-2007, 01:15 AM
the blur
the blur's Avatar
shorten the loop on the harnesses. Where is wrapps around the harness bar, that loop should be as small as possible.
Less belt to stretch should you ever impact....
Old 05-10-2007, 09:57 AM
cj68
cj68's Avatar
They are fine for street use. I just put them in my 02 Z06. Can't wait to get them on the track in a week.
Can anyone recommend a good harness and harness bar for these seats in an 02? I also want to be able to use the stock belts when not at the track.
Thanks,
cj
Old 05-10-2007, 05:09 PM
gpm30236
gpm30236's Avatar
Have those with the brey-Krause bar in my 01 Z06, very comfortable , love the adjustability.
Old 05-10-2007, 06:22 PM
JDIllon
JDIllon's Avatar
They are very comfortable, I just took a 2 hour ride to West Palm and back and they were fine. They seem to have great back support. JD
Old 05-10-2007, 07:16 PM
boerio
boerio's Avatar
Thanks,
cj
CJ,
I'm using the B-K bar and lap belt kit in my car. Purchased the bar from another forum member and bought the lap belt kit from ogracing.com. Also bought my G-Force belts from them.
Pretty easy to install, and they work great side-by-side with the stock belts.
Jeff
Old 05-10-2007, 07:46 PM
JDIllon
JDIllon's Avatar
Thanks, I will do that before the next event. JD
To New Caravaggio Races Seats Installed and NO codes
Old 05-10-2007, 08:18 PM
cj68
cj68's Avatar
Originally Posted by boerio
CJ,
Jeff
Thanks. I was looking at the BK... will probably go with that bar. OG is right near my house, so I will swing by there for the harnesses and lap belt.
cj
Old 05-10-2007, 11:47 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Beautiful!!!! & Perfect!!!
Old 05-11-2007, 07:15 AM
PA Z06
PA Z06's Avatar
Originally Posted by Z06cool
Very nice....
x2 they are awesome
Quick Reply: New Caravaggio Races Seats Installed and NO codes
