Hoosier tire fitment question
Old 05-06-2007, 08:47 PM
danbo56
danbo56's Avatar
Default Hoosier tire fitment question
OK... were did they go?
I've been running Hoosier 305-30 x 18 on stock rims on the back of my '02 Z. I went to the hoosier and tire rack site and they are no longer listed... ugh!
Has anyone fit up Hoosiers R6 315/30ZR18 or 295/30ZR18's in the rear? will the 315's fit?
tanks
dan
Old 05-06-2007, 10:05 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Looking at that myself for my GY slicks vs 305 they will fit. I will run them in the front and 335 rear.
Old 05-07-2007, 08:16 AM
Gordy M
Gordy M's Avatar
The 295's will fit a 9.5" wide rim so the 315's should fit a 10.5" rim
Old 05-07-2007, 09:35 AM
0Vector Vette
Former Vendor
Vector Vette's Avatar
The Hoosier 305-18 was really a 315-80 all along. Hoosier has just re-labeled the tire. It is the same tire.
Old 05-07-2007, 02:00 PM
TedDBere
TedDBere's Avatar
Kumho came out with the same width as the 305 but labelled it 315. Hoosier decided that if Kumho's width was a 315 then so was theirs! Voila, Hoosier 315. And I run them all the time on the stock rim sizes. Here's my latest picture:
Old 05-07-2007, 02:45 PM
80shilling
80shilling's Avatar
tanks
dan
I just got back from a Weekend at Sears Point/Infineon Raceway. I had my shop put on the 295/35-17's front amd 315/30-18's rear on the stock rims... PERFECT!!! Absolutely perfect.. no rubbing and PHENOMENAL grip and turn-in.
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
See the specs for appropriate rim width.. 295's are fine on a 9 1/2" rim, 315's are perfect for a 10 1/2" rim.
Old 05-07-2007, 10:56 PM
trackboss
trackboss's Avatar
For those running CCW's do you run 315 all around or go smaller on the front? I have a set I got from a friend. Fronts are 18x11 with 11.5" wide goodyears and rears are 18x12 with 12.5" goodyears. I have never ran them, but when I do I am not sure if I should go 315 hoosiers all around or just in back and 295's in the front.
thanks,
-V
To Hoosier tire fitment question
Quick Reply: Hoosier tire fitment question
