I need an LT1 sandwich-type oil cooler adapter
Looking for something high quality that won't crack or leak. Any suggestions?
TPIS sells a billet one for $100. Seems a little high, but may be worth it.
Received 8,927 Likes
Why not call Summit or JEGS?
Bill
Bill
Only thing I found on Jegs site was a real cheap no-name one.
Found a bunch on Summit's site, but they listed them by size and not application. Summit's site sucks the big one anyway.
The purpose of this thread was to see if anyone had anything positive or negative to say about any particular brand or style.
Try one of these:
http://www.racerpartswholesale.com/
http://www.hrpworld.com/
http://www.pegasusautoracing.com/home.asp
http://www.godmanhiperformance.com/
If you have the stock cats, you need to get a specialty piece that offsets the filter to the side (like the stock filter adapter does). If you don't have the stock cats, a standard SBC filter adapter will work which opens up a lot of lower cost options. I've seen a bunch on e-bay in the past.
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
If you want something that wont leak, forget the sandwich adapter. That design is crap.
LPE makes a nice reliable piece.
http://www.lingenfelter.com/Merchant...Category_Code=
I went with the mocal adapter with 180 deg thermostat from racers parts wholesale
MOC-SP1CT 13/16 THERMO PLATE 1.00 1.00 0.00
The total for your order is $120.07.
It doesn't necessarily have to be the sandwich type. The LPE type piece would work if anyone makes one for an LT1.
I'm running long tubes with no cats, so no offset filter needed.
These are not the stock sandwich type coolers where water is circulated through the sandwich. With these sandwiches, the oil is circulated out through an external cooler.
St. Jude Donor '08-'09
I use the Canton Racing Products adapter.
Bill
