GS 17 X 11 rims with 315's on a C5 FRC?
Old 05-01-2007, 10:04 PM
Solo2GS
Solo2GS's Avatar
St. Jude Donor '07
Default GS 17 X 11 rims with 315's on a C5 FRC?
I am sure this has been asked a thousand times, but here we go for one more!
Will the GS 17 X 11 rims with 315's fit on all 4 corners of a FRC?
TIA
Old 05-01-2007, 10:07 PM
Falcon
Falcon's Avatar
yes.
Solo2GS
Solo2GS's Avatar
St. Jude Donor '07
Thanks! That is what I wanted to hear!
Old 05-02-2007, 09:37 AM
varkwso
varkwso's Avatar
They will rub DRM brake ducts and depending on your ride height and spring rate may rub the fender a little bit. They rubbed my 99 FRC a little and cleared my ZO6 no problem.
Also some 315s are bigger than other brands of 315s....
Old 05-02-2007, 11:54 AM
yakisoba
yakisoba's Avatar
Yep. I run 315s on the front, but on normal front GS wheels. Goodyear fit fine, Kumho don't. Same size tire. Hoosier 295s are an excellent fit for the regular 17x9.5 GS front wheels.
UstaB-GS549
UstaB-GS549's Avatar
I ran 315's on my front 9.5" GS rims. Tires were GY GS-CS.
Old 05-02-2007, 01:23 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
I have 17x11 OEM GS wheels w/ 315 V710s on all four corners.... bought them slightly used, haven't used them yet.
To GS 17 X 11 rims with 315's on a C5 FRC?
Quick Reply: GS 17 X 11 rims with 315's on a C5 FRC?
