Recommended Brake Pads for first HPDE
This is my first time ever at an HPDE. I finally got up the courage to go. I will be at Watkins Glen 5/7 - 5/8. I have a '99 C5 with stock motor & 6spd, 3.73 rear-end, Nitto 555 tires, Pfadt Racing Sway bar, Koni FSD shocks. I am installing new NAPA rotors, DOT4 fluid but I'm not sure what pads I should install. I will be driving the car about 300 miles to and from the track for the HPDE. These pads and rotors are only for the HPDE. I have another set for daily driving. Any suggestions or opinions will be appreciated. I plan on doing about 4 or 5 more HPDE's this year if that makes a difference.
Stick with stock pads for now. You have a lot to experience before you will notice any difference from pads. Concentrate on your driving first, equipment (except for safety gear) second.
I agree with both AU N EGL and earthman01. Once you get some seat time and start developing smooth lines and more fluid footwork and shifting, then you can worry about upgrading your brake pads.
Do you have ducts? I found the stock pads got used up way to fast, made to much dust, and faded to fast. They were gone in a day and made the whole bottem half of the car black. Last time I was out I had Hawk HPS on and left them on, they had some fade but came back quickly with the ducts. They had good bite, low dust, and did OK for wear. I will be using just a track pad and rotor from now on, there are just to many compromises. I thought the stock pad at the track was dangerous.
Received 8,917 Likes
As a novice the OEM pads will do just fine. I ran my 97 at the Glen for 3 seasons without race pads. When I started running it in 97 there were no race pads only OEM pads. I was already an Advanced Driver with 5 seasons of experience so was pushing the car a lot harder than novices do. The stock pads will do fine if you start with a new set that has been burnished in for a few miles before you get on the track. If you are hard on your brakes the whole time they will taper (even race pads taper in the stock caliper) quite a bit over two days but since you are a novice I doubt you will abuse them too badly. If you start noticing the brake pedal travel increasing as the number of track sessions increases just let off the gas a second sooner and double pump the brake pedal to get it back up. I have instructed several novices with C5s and C6s and they did not have any brake problems using stock pads. They are also easy on the rotors. I went 3 seasons on the original rotors while using the stock pads.
Bill
Bill
Stock pads for the first one. After you get a few under your seat, and you'd notice the difference, change them out. Z06 pads are fine for your first couple of DE's, IMHO.
Some folks say that they fade. It's possible you will feel a bit, but with good DOT 4 fluid and good technique, it's not that common. Besides, you NEED to learn to deal with changing brake force and conditions. Time to start.
WOW! Thanks for all the encouragement and the advice. My plan is to take it easy and not get to overboard. I want to learn and have fun but since I'm getting new pads anyway just wanted to get a feel for how to go. Sounds like a street type pad is the best to start with. How do Hawk HPS compare to Z06 or some other?
Only street driving with these pads, rotors and wheel tire combo will be to and from the track. I have a different set of wheels, tires and rotor/pads for daily driving. I'm not really worried about dust, mostly about making it through a few 2 day HPDE's without having to buy new rotors and pads.
Bill
Bill
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,082 Likes
geerookie,
we have a couple dozen sets of Wilwoods in stock at great prices if you decide to go that route, both street and track compound. Feel free to call.609-752-0321
With that being said, for your first event the stock pads should work fine for you. I would however recomend changing your brake fluid though. Again we have plenty of Wilwood fluid in stock.
geerookie,
geerookie,
stockers can fade in one good shot. Yes you won't be flying the first time out you won't know what's coming next for 2-3 sessions. If you need pads why buy stock you probably over run them the next day your tracking. I see the BP-10 listed in the link right hand column. Even the E compound would be better than stock.
I remember my first HPDE, I way over used the brakes at first. I didn't know the track and I would over brake for corners creating a lot of heat.
I did 150-30 mph run on stock pads once. by the time I hit 50 I was lookin to open the door and get my foot out to stop. Faded in one shot try two in a row Like labeled they are street pads and what are you capbable of on the is mild compared to track events. You can never have two much brake, especially when starting you may go to deep. Novice will usually hit the brakes even harder trying to scrub speed vs experienced person with confidence.
Strictly a track pad get H compound and swap them out after the event.
[QUOTE=John Shiels;1560003111]especially when starting you may go to deep. Novice will usually hit the brakes even harder trying to scrub speedQUOTE]
That describes my first HPDE, I used to much brake and in cornering bobbled the car around to much, upsetting it. Learn to be smoooooth. After a few corners I'd come in, brake, everything would feel normal but the car would not slow down.
