ATE blue from January
Old 04-26-2007, 10:25 PM
the blur
the blur's Avatar
Default ATE blue from January
During the winter, I was bored; so I completely flushed my brake system with ATE blue. The car sat in the garage ever since, not even a test drive.
now, it's almost May, and I have a track event coming up.
Do you think the fluid is still good ??
I figure it got to be as good as any fluid in a plastic container, since the master is plastic.
what ya think ????
Old 04-26-2007, 10:39 PM
96GS#007
96GS#007's Avatar
Received 1,745 Likes on 1,053 Posts
Hmmmm...1 hour (or less) of your time. $10 worth of fluid. Peace of mind.....
It's probably ok. However I'd bleed it, but that's just me
Old 04-26-2007, 10:50 PM
rikhek
rikhek's Avatar
Oh God, not again?!?!?!?!?!?!?!??! I'm starting to think some guys start threads like this just to see if anybody is gullible enough to fall for the question.
OK I'll bite...... the DAMN fluid is fine and 5 years from now it will be fine and probable five years after that will be fine. It's freakin' brake fluid.
And yes I know all about water absorption, blah, blah, blah,
Rick
Old 04-27-2007, 10:31 AM
larryfs
larryfs's Avatar
appearently you never boiled fluid on the track.
Rick
Old 04-27-2007, 10:49 AM
FasterIsBetter
FasterIsBetter's Avatar
what ya think ????
IMHO, unless you left the cap off the master cylinder and live in an area with 95% humidity most of the time, you should be fine with the fluid. I've run ATE Super Blue in a variety of cars over the years, change it in the spring and it's still fine in the fall. You should be fine with it now and through the whole season. But if you're ****, do a quick bleed.
Old 04-27-2007, 10:57 AM
xsiveone
xsiveone's Avatar
It should be perfectly fine. I'd just bleed the brakes to be sure.
My question is.. Why doesn't ATE Blue and Amber make Green?
Old 04-27-2007, 11:31 AM
2000BSME
2000BSME's Avatar
Originally Posted by xsiveone
My question is.. Why doesn't yellow and blue make Green?
(sorry, had to alter your text for effect)
Old 04-27-2007, 03:11 PM
rbl
rbl's Avatar
What does that have to do with the question or with rikhek's comment
Old 04-27-2007, 03:25 PM
larryfs
larryfs's Avatar
because he says 5 year old fluid is fine, and we all know 5 year old fluid will boil after 2 laps.
Old 04-27-2007, 03:48 PM
rbl
rbl's Avatar
OK ... yep, missed that part!
Old 04-27-2007, 03:55 PM
Aardwolf
Aardwolf's Avatar
I'd run it! I bring fluid to the track, if there were an issue I would change it there, it's quick to do!
Old 04-27-2007, 06:48 PM
ScaryFast
ScaryFast's Avatar
My vote is also "it's fine but bleed them".
Just ran Mid-Ohio last weekend on year-old superblue, no boiling, no problems...and yes I use the brakes hard. Got mild fade (with Brembo big brake kit) on one of the faster sessions, but not due to fluid boiling, just hot pads. They came right back next session without a bleed.
Old 04-28-2007, 12:53 AM
rikhek
rikhek's Avatar
I did boil fluid prior to switching to Super Bluea couple years ago. I now purge the calipers every 3 track days. With him having put no heat to the fluid in the calipers there's no need to even bleed.
I've found 8-10 pumps to the calipers every 3 track days keeps a constant supply of good fluid in the system.
I'm really wondering if I should change the air in my tires. It's been in there for over a year and smells stale.
Rick
To ATE blue from January
Quick Reply: ATE blue from January
