multi-use tires
multi-use tires
Can I run those new non runflats from Nitto, the InVo. They make the size for the rear of the Z06 but not the front. My back tires are worn quite a bit. The fronts are not bad. Can I track the car with the new Nittos' in the rear and the stock EMT's up front? The tread wear is the same so I don't know if traction will be any better. But the EMT's do perform.
I ran the car on the track with the EMT's and was able to pull very respectable times, faster than many runnig slicks.
