carbotech pads cracking?
I have a set of xp10 front pads that I've used for 2 weekends and they still have 50% material left. The pads are cracked in the center of the pads. The 3-4 cracks start in the dead center of the pad and continue out of the center in a star pattern almost to the edge of the pad. Are these trashed at this point? The cracks don't appear to be very deep but if this is not normal i dont want to use them this weekend. Any advice? I tried calling carbotech but I can't find their number. The web site is not working. Anyone have the phone#
This has been my experience also, cracks and chunking at the edges. Absolutely no problems with performance, they look ugly but still slow me up in time for the corner everytime. I have worn even worn them down to the rivets by mistake...
Thanks for the replies! I will run them this weekend and see how they do. I have a new set I will be taking just incase. I think I will pull them and inspect after a session or two.
I've gotten single cracks before - would keep an eye on them though, because carbotech's are attached with rivets (three points) rather than a continuous attachment like the wilwoods (to the best of my knowledge).
They have a new website:
http://www.ctbrakes.com/overview.html
I just finished off a set of XP8s and noticed when I got home that one of the front pads had cracked. I ran them down pretty thin. They made the 6hr drive each way to Roebling and lots of time on track. First time I've ever cracked a brake pad. The XP10/XP8 setup I'm using now is not cracking or chunking and they are probably only good for another weekend.
The old site had a FAQ about why they still used rivets. The best I can recall, is that the pads were bonded and rivets were just in case. I can't find that FAQ on the new site, but I have found they are always willing to answer questions if really need to know.
Graham - So - can you tell the difference in lap times with the XP10 vs the XP8? I have run XP8, 10 and 12 at multiple tracks. I see a difference in rotor and pad life with the more aggressive pads - have not noticed huge differences in braking though. I have a couple boxes of pads from BPKM (mostly rears - 10/12s I think) which means I will need some 12's up front to use these up. I am currently using ~3 front sets to 2 rear sets....
I run them with cracks - it seems to happen at about 1/2 pad life...
I'd say if you're getting through a 20-30min session, in the summer months, and don't have a complaint about brake fade just stick with the XP8s for DEs. Save your XP10 or XP12 fronts for your time trial sessions to get that little bit extra. I have a brand new set of XP12/XP10 that I got from someone who decided not to use them. So I'm trying them at the end of May for 3 days on VIR Full. I'll have an extra set of front rotors that are bedded in. I suspect I'll crack the current rotors that weekend. I have noticed that with the XP10 I got pad taper quicker. Maybe the calipers are just getting worn out. I'm flipping the pads across the front wheels for every event. Might even do it each day for the 3 day weekend. I hate to waste expensive pads that a quick swap could help.
I just upgraded my brake ducts and added home made spindle ducts so now I'm getting air right into the rotor hub. We'll see if it helps any.
The XP8s on the rear are wearing very well with no taper. I suspect 2-3 sets of fronts to 1 set of rears.
Once these are all gone I'm going to try some Ferodo DS3000 and see how they compare.
Well the xp10's held together this weekend. I wore them down to the rivets with no issues from the surface cracks. I experienced a lot of pedal vibration and it got worse the thinner the pads got. I also noticed excessive pad deposits (might be the cause of vibration) on the front rotors. Is anyone else experiencing heavy pad deposits with the carbotechs?
I haven't pulled the pads off of the car yet so can't tell if the cracks got worse but after day 1, there was a hairline crack down the center of each pad.
-Matt
