Toyo RA1's vs Hoosier ??
Has anyone tried both Hoosier R6 and Toyo RA1's?
How much slower are the RA1's and then how much longer do they last?
I do several open track days and have always used Goodyear GSCS's (DOT race tires) but wear is a real problem....I am lucky to get 4 days out of a set. I do push the car pretty hard, as I have been doing the lapping days now for years!
Trying to reduce my costs a little....your opinions would be very much appreciated!
Thanks...jdm
Thanks...jdm
Thanks...jdm
Thanks...jdm
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
Thanks...jdm
Thanks...jdm
Thanks...jdm
Thanks...jdm
I've used the Hoosiers, Goodyears and the Toyo RA1's.. I've found that the grip is best with the Hoosiers, then the Goodyears, with the Toyo's offering the poorest grip. As far as track life is concerned the Toyo's will last longer than either the Hoosiers or the Goodyears. If you're looking for more miles per $$, then the Toyo's will serve you best, but if you're looking for lower lap times and greater cornering grip, go with the Hoosiers.
Jim
Toyo's are very slow. They have too much tread to be used without shaving, then don't last very long if you shave them to WC depth. Not a good choice unless you are forced (by rules) to use them.
Thanks everyone for your advise!
Frankly, once I am out on the track my goal is to go as fast as possible.
Thought maybe I had found a lower cost option.....seems there is no replacement for Goodyear or Hoosier!
And yes AUTO_X_AL, I do run at Waterford......actually go to the Shelby Club events....they are a blast for those in out area. (I have a Mustang track car also).
Maybe this year I will try another track or two!
Any thoughts on the new BFG R1? I used to run those years ago....they were great but no match for the then new GSC-S's.
Thanks.....jdm
Thanks.....jdm
I see many people running Kumho tires (the treaded DOT Victoracer) at track events with a better car than I have, and consistantly run 2-3 seconds slower on our 80 second lap track.
I have also been told that the Hoosiers are better from laps 1 to 6 then about lap 8 the Goodyears are faster.
Guess you only get what you pay for!
toyos are cheaper and (in my experience) last a lot longer...hoosiers have more grip until they are "cycled out" then the grip falls way off and is less predictable...
for driving schools, i don't see the point of buying new hoosiers...they aren't going to make you a better driver...
Goodyear sells them through their distributor called Competition Tire.
We have one in Michigan and you can order the tires and they will deliver on a regular race day to your local track. That is what I do and they mount an balance on the spot for me at Waterford Hills road race track.
You should be able to find contact info from the Goodyear website.
jdm
Really, comparing RA1s to Hoosier R6s is like comparing apples to oranges. Nobody, including Toyo, would claim that the RA1 serves the same purpose. It's a "drive to the track" tire. Try that with the R6s!
http://forums.corvetteforum.com/show....php?t=1684923
Joe
Already had this debate in another thread........
Joe
Joe
Someone should make a FAQ about autox/track tires.
Yep this is a comparison about different types of tires. I see in the Z06 section where people constantly compare running a Nitto R2 to the GY F1 Supercar. Apples and orange... I class them apart more like this.
Hoosier R6/A6 + Kumho V710 = r-comp, super sticky, 40 treadwear.
Toyo RA1, Nitto R2/NT01 = r-comp, sticky, 100 treadwear.
Supercar, RT-615, PS2, KD = High end street tire, sticky for a street tire but not like an r-comp, ~200 treadwear.
These tires fall in different categories of competition. To compare a Supercar to an R2, or an RA1 to a Hoosier isn't equal.
